Korm brought forth a very important point that many people miss, or it seems counter intuitive.
We have a number of concerns:
- visual: kinked track does not look good
- operational: bad kinks or track movement can cause derailments
- operational: rails pulling from joiners can cause derailments
- operational: rails pulling from joiners or excessive movement can cause electrical issues.
So, when the rails expand, they push against each other and grow in length. On curves the track moves outward, on straights the overall length will grow.
So you get track movement and kinks.
Now when the rails contract, the rails shrink, but the rail joiners do NOT “pull” the rail back into the joiner, usually you get gaps. There is no physical reason that the rails would be pulled back into the joiners.
Here’s where people get confused: when the rails expand again, they assume the rails will push into the joiners and take up the gaps.
NO, this does not happen. Why? Because there may be less resistance in the track moving, then trying to slide back into the joiner. Also, the gaps that were created are NOT distributed evenly, the gaps have to do with the resistance to movement at each location, some joiners will be tighter than others, some areas of ballast may have more resistance.
You REALLY complicate matters if you try to screw the ties to something in multiple places. Now you provide more places that forces cannot equalize. There is a reason that after years of experience, prototype track is STILL in ballast.
So, I lay my track without gaps on a warm day (just like railroads), and make sure I have some curves in long tangents. Works fine.
I have a friend that had concrete laid, LGB sectional track, and glued all the track to the concrete. Over time gaps developed and ties were ripped from the rails.
There has to be some give, just “gentle” securing of the track, and you cannot completely overcome gaps in all locations.
