GAP,
The second flight will definitely use the technique outlined above. I think that styrene will, in the end, give me more uniform parts. Even using my very simple journals, getting them to the same size and then boring out a whole for the axel has been a bit of a challenge. On the other hand, I got all the timbers cut today:
On the left is the sum total of my waster material. Given the timbers were a gift, I am proud of who little waste material I generated! The leftmost pile of parts required a bit of imagination. I had originally cut all my beams too short. I trimmed one back, sanded the ends, glued it, braced it, and here we go. Waste not, want not. For the record, I cut most of the parts with my saber saw. I found the little hand saw was more accurate and only a trifle slower, but I really am trying to master the powered saw I bought a year or so ago. This project, which has a lot of tolerance for error, has been a good one in that regard.
I’ll close where I began, the journals. For reasons that defy explanation, I had a devil of a time managing the art of getting a vertical hole smack dab in the center. I am going to have to see if YouTube has a means to jury rig a “bench dress” with my power drill. To add insult to injury, the wood decided to splinter as the drill broke through. Not enough to be structurally significant, and I can mount everything so that the most egregious splintering faces inward, but, geez! I also made things a bit easier on myself, using grommets on both the inboard and outboard sides. The exception were for the splintered blocks, where, for want of surface area near the surface, I cut a small bit of tubing a I did for the first on the series.
Couplers, wheels, track tests, then we’ll plank the lot!
Aloha!
