No, I just read and looked at the pictures.
Well, no wonder it did not work completely, he heats it up and hopes it is in better alignment.
And he had to do it twice. Oops, make that 3 times.
And he did not wait long enough for the solder to cool between joints.
Other than that, and the fact when I did it it worked the first time, no difference in methods.
My theory is that the motors were not exactly square with the gearboxes, so by applying pressure while re-melting the solder, you use the motor block and the pressure to align the motors. Ray’s hit and miss may eventually work, but I’ll bet you that he’s also melted part of the gearbox the way he’s getting in there.
Now I understand why you have to keep doing it, because you have no reference of aligning the motor.
