Wendell Hanks said:
MORE TRACK QUESTIONS…
Gargraves, in my memory, is cheaper than the USA/LGB/PIKO/B’mann offerings - is this still correct and if so by how much?
Is the durability outside a problem considering it is tubular steel - not stainless, I think.
Personally, I have handled and shaped Gargraves but was hesitant installing outside from word-of-mouth cautions.
I think we will all appreciate your assessment of durability and efforts to maintain rail surfaces for those of us still using (blush) track power.
Many thanks,
Wendell
Hiya Wendell…much cheaper yes, including switches which they make to order (or did when I bought them) and I’m getting to like the look more and more the more I work with it.
I use onboard power so I’m not an expert there, but I seriously doubt that the switches at least would be reliable or easy to use with track power. I think the track itself would be fine and if you are adept at fiddling with electricity and switches maybe you could make it work.
Outdoors on the ground? No no no, oh no. You’ll crush it sooner or later. Outdoors on an elevated track, probably okay as far as the rail goes but I seriously doubt the light wood ties would hold up very long. Not to mention the swelling and contracting that would occur as the ties got wet and dried and froze and heated.
All in all, I think it’s a good solution for my raised layout under the back porch, or for indoor use, but I can’t see this track working outdoors.
That’s my experience and judgement anyway for what it’s worth.
p.s. I edited this to read onboard power instead of battery power because it make me feel more like an adult railroader and less toy-like! Ha!
