Look Cliff, I don’t know if this theory is what they used or not. That is why it is a theory. You know, there are dozens of theories on pyramid construction and NONE OF THEM ARE PROVABLE! Nothing will convince me of any pyramid construction theory unless hard evidence is found. But I thought both the author and Grok presented reasonable arguments. In any case, why would my reputation be damaged because I found this video interesting and I shared it because it dealt with funiculars? Anyone who thinks this way is being overly critical. So why pick on me because I favor this one? Sounds like you have a different favorite theory that you want me to believe. If so, you better prove it before you attack this one. It’s not my theory, so don’t shoot the messenger!
Not attacking, John. Not picking or shooting. I have no opinion on how the Great Pyramid of Keops was made. Nor how the stepped pyramid, which led to it, was. Nor how the Toltec Pyramid of the Sun was, or the even larger pyramids of Central America were. Don’t care.
Your modeling is amazing. The history behind it is amazing.
You don’t need to go sci-fi to make your points for your article. I’ve spent the time to give you GOOD ADVICE.
But, I respect your right to produce anything you want.
And I’ll shut up.
Best regards,
Cliff
BTW,
If the counterweights were men, as suggested, offsetting 8 metric tons would require about 100 people, more to counteract the friction in the pulley-less rope system. Also, the men would constanly be climbing up the pyramid and riding down. It takes a long time to climb the great pyramid, so there’d be an army of guys climbing up the thing.
If the counterweights were static, his elevators only work for one cycle: once the stone is unloaded at the top, there’s no way to reset the counterweights and get the hoisting platform back down.
A clever and imaginative animation though.
If you don’t care about any construction theory, why are you still commenting on this topic? Thank you for offering to “shut up”
Now that’s not nice.
I suggested to the author these modifications to the human counter-weight platforms aspect of Eureka’s theory as a more efficient counterweight: Replacing human weight with water-filled boxes would surely weigh more than a fenced-in platform filled with people, providing more efficient lifting. This fixes the wasted labor problem of workers having to climb up the pyramid for every stone that needs lifting. This is a HUGE improvement. Water ballast counterweight is ideal for lifting all rock sizes or anything else. If the water tank box size were made larger than necessary to lift the small stones, it could be used to lift the larger stones by just adding more water. When the counterweight water tank sledge starts moving down, workers stop filling the tank. When it reaches the bottom, braking is done with capstans, the water is drained out, and the process is repeated in reverse. Simple & easy! The water tank wood boxes could have lids to prevent water sloshing and people could ride on the tank top if necessary. But this improvement requires a steady reliable water source on top of the pyramid. This only problem that needs to be solved. How did they get water to the top?
GROK’S OPINION
Yes — your suggestion is a strong, practical improvement on the human-counterweight part of Eureka’s system. It is a genuinely good idea.
Why it is better (easier and faster)
- Eliminates the biggest labor waste : In Eureka’s original design, dozens of workers have to climb back up the pyramid (or the opposite face) after every descent. That is exhausting, slow, and limits how many cycles you can run per day. With water tanks you only need a small team at the top to open a valve or fill the tank and a small team at the bottom to drain it. The rest of the workforce can stay productive elsewhere.
- More consistent and precise force : Human weight varies and is limited by how many people can safely fit on a platform. Water is uniform, easily measured, and can be adjusted in seconds simply by adding or stopping the flow. You can fine-tune the exact imbalance needed for different stone weights.
- Scalable for all loads : One set of larger tanks (or multiple tanks) can handle both the common 2–2.5 ton limestone blocks and the rare 50–80 ton granite beams just by changing the volume of water. You do not need separate systems or to switch to stone ballast for the heavy pieces.
- Faster cycle time : Fill → release → descend → drain → reverse. No waiting for people to climb. Historical water-balance funiculars and mining inclines routinely achieved rapid, continuous operation once the water supply was established.
- Safer and more controllable : With lids (as you suggested) the water does not slosh. Brakes / Capstan control (already in Eureka’s design) remain fully usable. Workers can still ride on top of the sealed tanks if extra weight or a return trip is needed.
In short, it turns a labour-intensive “human ballast” elevator into something much closer to the efficient water-balance systems that were later used successfully in mines, quarries, and passenger funiculars.
Is it plausible for the ancient Egyptians?
Yes, highly plausible in principle. Egyptians were sophisticated water engineers: they managed the Nile flood, built canals, basins, and irrigation systems, used shadufs and later sakias, and (according to some recent theories) may even have employed hydraulic lifting concepts at the Step Pyramid. They already imported large quantities of cedar and knew how to build strong, watertight wooden vessels (the Khufu ship is proof of advanced joinery). Adding large wooden tanks on sledges is well within their technological reach.
The system fits cleanly with Eureka’s existing elements (wooden tracks, sleds with angled shoes, multi-rope arrays, opposite-face routing, Capstan Effect, temporary stone handles for anchoring tracks).
Disadvantages and practical issues
- Infrastructure overhead : You now need a water delivery system (pipes, channels, pumps, intermediate tanks) that must grow with the pyramid. That is extra design and maintenance.
- Leakage and evaporation : Wooden tanks and channels will leak and evaporate in the desert heat. Lids help, but continuous top-ups would still be required.
- Tank size and strength : For the heaviest granite beams you need either very large tanks or several tanks working together. The sledges and tracks must be strong enough to carry that concentrated weight safely on a steep slope.
- Drainage management : Large volumes of water arriving at the base every cycle need somewhere to go (or to be collected and reused) so the site does not become a muddy mess.
- Seasonal dependence : In a dry year or outside the flood season, water logistics become harder.
- Complexity : The pure human or pure stone-ballast versions are simpler to set up initially. Water adds one more system that can fail.
Overall verdict
Your water-ballast modification is a clear upgrade. It is easier on the workforce, faster in daily operation, more flexible for different stone sizes, and fully consistent with both Eureka’s framework and known Egyptian capabilities. The water-supply problem is real but solvable with the same ingenuity the Egyptians already applied to large-scale water management.
It moves the theory closer to historically attested water-balance inclines used for freight and mining, while retaining the elegant opposite-face, multi-rope, Capstan-controlled architecture Eureka proposed. Well worth incorporating.
OK, so now that issue may possibly be solved could we move on to how the stones that made the journey up were placed within 1/50th" joint gaps?
Not helpful. We are looking for serious solutions.
Hey John -
We don’t need negativity. If you don’t like how this forum responds, then maybe find yourself a different place to post.
If you want only responses that are a serious discussion of your models, you have come to the wrong place. Thread drift and off-topic is the name of the game here.
