Favour needed
Ok fellers. Thank you all for checking and for the feedback. It looks like the article will be a no-go since the stuff isn’t readily available. Excretus accidat!
Phil,
Still haven’t answered my question though…why ECO Block and what is the purpose?
David Russell said:
Phil, Still haven't answered my question though....why ECO Block and what is the purpose?
http://www.largescalecentral.com/LSCForums/viewtopic.php?id=11955
Phil Creer said:
Ok fellers. Thank you all for checking and for the feedback. It looks like the article will be a no-go since the stuff isn't readily available. Excretus accidat!
Guess you are not looking up the page - the guy on the phone said that they would supply any and all you wanted, however big or small.
I’d call that ‘readily available’ but maybe my funny accent is getting in the way of comprehension?
tac
www.ovgrs.org
Thanks tac, I understood but it doesn’t suit Marc’s criteria for a GR article. By ‘readily available’ he means something you can go into any local hardware shop and buy off the shelf (as we can here. 2ft X 8in X4in block =$4). I’ve had this discussion with him before re other supplies and can see his point of view.
Again, thanks to everyone for your efforts and assistance.
Phil Creer said:
By 'readily available' he means something you can go into any local hardware shop and buy off the shelf (as we can here. 2ft X 8in X4in block =$4). .
OK that was the answer I was after! I was aware of your use but didn't understand why it needed to be so thick. We have 2" thick 4x8 sheets readily available but nothing thicker than that unless it is ordered.
David, if those 2" sheets are READILY available they’d do the job. Can you get a scrap and see how well they carve/scribe using e.g. a screwdriver tip? Scribed like this?
(http://photos-a.ak.fbcdn.net/hphotos-ak-snc1/hs246.snc1/9319_1198470155173_1031079018_30614758_1367426_n.jpg)
Scribing on blue or pink foam insulation board (it comes in 3/4" to 2" thicknesses) needs to be done with a hot wire cutter. A screwdriver won’t do it. A sharp exacto knife might. Some projects -
(http://i113.photobucket.com/albums/n214/altterrain/building%20projects/IanvilleStat1.jpg)
(http://i113.photobucket.com/albums/n214/altterrain/mine%20diorama/mine-dio-left.jpg)
-Brian
Phil Creer said:
Thanks tac, I understood but it doesn't suit Marc's criteria for a GR article. By 'readily available' he means something you can go into any local hardware shop and buy off the shelf (as we can here. 2ft X 8in X4in block =$4). I've had this discussion with him before re other supplies and can see his point of view. Again, thanks to everyone for your efforts and assistance.
Ah, confusion here. You wrote 'GR' but not until you mentioned Marc Horowitz did it occur to me that you were writing about the American 'GR' and not the British 'GR' in which Australians and Kiwis have both written over the years.
Next time I’ll keep me trap shut and me mind open.
tac
www.
I actually prefer the pink and my Washington St Station in my avatar is made from it. I actually did carve the siding with a flatblade screwdriver. Didn’t have the same luck with the blue as I found it less porus than the pink.
But either one is quite available here. (link my be too long)
http://www.homedepot.com/Building-Materials-Insulation-Sheathings/h_d1/N-5yc1vZ1xhwZbaxx/h_d2/Navigation?&storeId=10051&catalogId=10053&langId=-1
Here’s the contact information I received for locating Hebel in the states…
Mark Booth
D.O.D Project Manager
Xella Aircrete North America, Inc.
2400 Hebel Boulevard, Adel, GA 31620
www.buildwithhebel.com
Office: 229-896-1593
Mobile: 229-212-0130
Fax: 229-896-1912
Email [email protected]
Jon.
