Your motors will be fine with the PWC output. Sound systems may go crazy though, no damage, just act funny. Lighting will come on earlier. Slow speed performance will be enhanced. Many new LGB locos come with built in DCC decoders (they call it MTS), these locos might act funny if not set for analog only operation.
On the DCC question, I will comment inline:
Matthew (OV) said:
Greg Elmassian said:
DCC is basically square wave AC, not DC, with basically a modulated frequency. The modulation in frequency is the data. Scroll down this page to see a DCC waveform http://www.wig-wag-trains.com/AHD/AHD_RRampMeter%99_Product-Page.htm
Regards, Greg
Are you sure about that?
YES!
I know in DCC that waveform (the one on the site your link goes to) works (which is what that site’s mostly about.)
Not only works, but the point was that it is AC, it has both positive and negative components, look at the link.
DC is always between 0 and positive or 0 and negative, it’s Current never Alternates… (Alternating Current - AC)
I made that point because someone said DCC was DC…
I was always under the impression, though, that PWC was exactly half of that waveform …
sort of similar, if you cut half of the DCC signal, it LOOKS SIMILAR, but is completely DIFFERENT in how it works, the modulation in DCC is decoded to data, a pulse width modulated DC signal is just narrower or wider pulses that make the motor go faster or slower… DCC is digital data encoded in an AC power supply, it surely does more than change the motor speed.
everything ABOVE the zero line for one direction, and everything BELOW the line for the other
Execpt in DCC you ALWAYS have the postive and negative pulses, in PWC they are either postive or negative… if you put a DC loco on the DCC track, it sees it as AC and just buzzes…
… with the modulation being a controlled interval of “on time” for the half wave. That was also how their “linear” output worked; they put a capacitance circuit in the PWC line that “held onto” the on time for long enough that to the equipment it looked like linear DC… if you did this with a waveform that was as equally above the line as below, you’d have relative zero, and wouldn’t go anyplace… 0 -1 +1 =0.
Along those lines, with a DC motor, if you fed it the waveform in that picture, wouldn’t you have just as much backward direction power as you would forward, causing a buzzing sound, but not much motion?
Again, no motion at all… heat though!
Since a PWC power supply is designed to run decoderless locomotives (i.e. motors more or less directly connected to the track) there’s nothing aboard to sor…
The big difference is that PWC is just a modulation technique to change the speed of a motor, and using full voltage in modulated pulses has benefits in torque and slow speed starting…
DCC is Digital Command Control, the modulation is data, like that which flows over the Internet, which can be used for many purposes, but without a decoder, is not intended to run anything. Now you could rectify a DCC signal, and pick a data pattern that could run a locomotive, and this has been done to allow a kind of analog capability to run ordinary DC locos on a DCC track, of course only one loco…
I admit that I could be completely out to lunch here … so if I’ve always misunderstood how this works, don’t shoot!
Well, I’m not shooting, but you did have a bit of a meal there!
Matthew (OV)
Regards, Greg
