Great thread!
FWIW, here’s what I use.
- Mr Mister lines & sprinklers like Ken mentioned, very fun and easy to install, adjust and make changes / additions to.
- Two Rainbird anti-everything zone valves, which worked perfectly for a whole year.
- My controller is an Orbit “4-Station Indoor/Outdoor Swing Door Timer.” This thing is highly programmable, allows 2 programs per day, time settings for up to 4 zones per program, accepts rain sensor input for user-selectable rain delays, etc. Runs off 120vac input, which you have to supply from a GFCI; but has an internal battery to keep its clock & programs going when power goes out (which we experience a lot of). A lot of functionality foe only $35 from Lowes (when I got it about 4 years back).
- I run the system from a tee and check valve from my main house water line.
Here’s the "control panel, with (from the right) shut off, filter, valve manifold and drain-vent cock.
I’d like to replace my control valves and put something simpler in – like basic solenoid valves, without any diaphragms to stiffen or bust. But that would force me to a more robust BFP, and I haven’t seen cheap versions of those.
So like I said, great thread, thanks for starting it Devon, and I appreciate the knowledgeable responses.
Cliff
