Time to move on to the cab construction. I decided to construct the cab entirely from wood to gain the effect of a very early Mogul design. Prior to metal cabs that is. The cab was constructed in two layers. The inner layer was made from1/16â plywood and basswood strips.
The outer layer was entirely basswood. All parts were stained golden oak and sprayed with a semi-gloss clear coat.
Here is an interior shot of one of the sides. Brass channel strips have been added to allow a window to slide in. All window frames were made as separate units and glazed with clear styrene.
The four doors were constructed from three layers of basswood. This design would allow the glazing to be inserted from the top.
Hereâs a photo of the completed cab. The roof was made removable so that one could appreciate all the plumbing details. The roof covering was strips of aluminum duct tape painted flat black. The grab bars were fabricated using brass rod and modified Trackside Details parts. At this point I want to mention the lack of photos showing the hinge installations. All doors operate. I will show a close up of the hinges at a later point.
Another thing to note is the brass strip that was added to the deck. These early wooden decks had metal edging added to protect the wood.
Now to move on to the tender construction. As it happened, building the tender turned out to be almost as much work as the engine. Of course, there were many photographs of tender exteriors, but nothing showing the underside. I could have just done a minimum amount of work to the frame and who would have noticed, but for me that wasnât enough. The only thing I found, and I donât remember where, was one lousy drawing of a typical tender underbelly. So, I took it from there.
I took the design and produced a scale drawing to create a build plan. The construction consisted of styrene strips and a few basswood pieces. In addition, notice the small brackets that run along the outside of the frame. Well, I made a drawing and had my son print a few. I wanted these because you could see them on the side of the tender. Hereâs a photo of the completed undercarriage prior to painting. The brackets are in grey.
This is the completed tender chassis (rear view). Everything has been painted satin black and basswood decking planks have been added. I modified an Ozark Miniaturesâ link and pin coupler to accept a Kadee knuckle coupler. It turned out that the Bachmann Spectrum 0-4-0 trucks were perfect for the Mogul tender in every respect. Saved me a lot of work.
I mounted another Ozark L&P coupler to the front bolster. This would accept a tow bar at the rear of the engine.
