Eric Schade said:
…that would be cool vs spending thousands on a laser…if it actually works. the veneer is thin,
LASERS… You can now buy them (blue beam types) for about 150 to 500 dollars from Banggood. and others…(depending on wattage of the laser head). Max they have is 5 watts…but it does a decent job on up to 3mm proper LASERPLY with a couple of passes.
Ordinary ply has different glues and is very difficult to cut with these smaller machines.
They can also cut/engrave other materials. Prices vary vendor to vendor so look around. being Chinese don’t expect any technical help that’s why a dedicated forum was started for lots of info on setting up and operating them at www.bencutlaser.us.
The program that comes with them is ok but it is best if a separate program is purchased from the forum. (I am not connected with the forum except as a user!)…
There are 2 programs available to suit either engraving and or cutting…($39.95 each). You can use them to test before buying them so that you get the “feel” of them .
No other program is suitable for operating these lasers. This is the only forum you will find dedicated to these machines…
NOTE…NEVER CUT PVC material(s) with a laser unless there is an absolutely ai****rtight exhaust system…it’s toxic. It is advisable to “box” these machines with an Orange plexiglass viewing window in the top AND for you AND others in the area to wear the appropriate colour safety spectacles (usually for Blue laser beams, Orange) when the machine is operating.
