Jon Radder said:You know that means that the starter motor and the A/C pump are next in line, don't you? Don't forget the voltage regulator and the fuel pump. If your motor has a distributor, it is well worn and needs a rebuild, as does the carburetor, if you have one, the fuel injection system if you don't. It could probably stand a valve job, too, which will lead to bearings and rings in short order. When was the last time the transmission was serviced?
After they road-tested the water pump repair they decided that the alternator was on its last legs too, so we opted to have that done at the same time. We finally arrived in WNY after 9PM, about 7 hours behind schedule. The remainder of the trip was fantastic. Couldn't have asked for better weather.
I was an automotive service writer in another life.
Your best bet is to jack up the radiator cap and install a new truck under it. :lol:
The dealer gave me the part back. A box of fragments plus the impeller/shaft.
