Well he wasn’t specific now was he. Track on the ladder of the reverse loop could be soon. I am done for the most part moving dirt to this part and shouldn’t have to worry about stepping on any of it.
I got the last two PVC posts put in to support the ladder and built the retaining wall for the reverse loop section and moved in a bunch more dirt.
And here is the area under the bench. The section of ladder that is outside of the rock will be a trestle someday.
This pretty well completes this section. I will need to bring in some crushed basalt to surround the ladder and then back fill to the top of it with dirt. I might do this tomorrow. I will at the same time fill in the steps with the same crushed basalt only I will sift out the fines and use it later for ballast. All of the walk ways will eventually be the crushed basalt with the fines taken out of it and used for the ballast. Killing two birds with one stone.
After that process or in between, I will need to bring in another truck load of dirt and another truck load of rock to continue on with the raised bed. The back sides of the raised beds on the fence side will be made with 2X8 pressure treated wood. I also ab about ready to add the next section of bench which will include where the wye is going.
