(http://1stclass.mylargescale.com/rkapuaala/coach64/sash_test_1.jpg)
I started on the sash early this morning. I made some mock ups from Styrene, and then assembled one bottom sash from some 5/64" koa a ripped up. Koa, is very brittle, and the rabits I tried to machine in broke off. To add to my frustration, when I test fitted the piece, the butt joints failed. I scratched my behind for a little bit and came up with the solution you see above. I took my styrene mock ups and some super glued some koa veneer to them. Using a razor knife, I cut out the edges and then cut around the inside of the sash at an angle to form my rabit. Wa la, vynol clad sash! I don’t think that was available in the 1930s so the purest in me is screaming “abomination!”, But the pragmatist is saying, “This works”
(http://1stclass.mylargescale.com/rkapuaala/coach64/sash_test_2.jpg)
The inside view isn’t pretty though. since this is a test window, I will just scap it and on the finished ones, I will run the koa veneers along the stiles and rails so that they are going in the right direction and look right. One thing is for sure, they are sturdy, and the glide smoothly up and down with just a snug enough fit to hold them in place when they are open. The two images above are just pressure fitted in place.
