Nicolas Teeuwen said:
" Rooster " said:
John Passaro said:
you’d go crazy trying to wire all of this
Why?
My first phase already had issues with shorts due to the turn outs connecting the dog bone as it does. Adding another level would likely increase this complication. Thankfully I am not wiring any of it as I took advice and went battery powered a while ago. At some point soon, before the second phase I am going to try running my holiday train on it. I’ll have to put insulators between those turn outs at the top though to prevent it from shorting. I have no idea if its going to work, due to the size of the track. If its going to work though now is the time to try before the track is too dirty.
Shorts…Shorted out locomotives…
PERFECT CONNECTIONS…OR ELSE YOU PAY!!..What? Frog snot???
Insulated frogs…reverse loop wiring…insulated reverse loop wiring…
One-way electrically wired switches…two-way switches…
Dirty track…inconsistent voltage/amps/whatever passing through the track…trains speeding up and slowing down…
DCC zones…DCC…oh yeah, DCC systems…different manufacturers…
Screwdrivers across the tracks and everything else that can go wrong accidentally…
Complicated wiring schemes and plans and all that wiring all over the place…
Almost impossible to run more than one train on a track…
Soldering…OH MY GOD…soldering…
That’s what I call going crazy! But that’s just me. I know a lot of guys swear by track power and that’s okay too.
