Bob McCown said:The range should be OK as long as no daylight gets into the equation. Infra red does not work well in daylight. Fantastic range at night.
Anyone know the effective range of a photo transistor/irLED pair? Would I be able to use it over a span of say 10" to detect a 1:20 train in between?
Hmm…thanks Tony… .I think Im going to need to build some sort of aimed ir, or use simple photocells or something. I have block detection working on sections of track, but since switches are all one big connection, I cant detect rail-to-rail, so I was hoping to use some sort of visual detection. Guess its time to experiment!
I use visual detection on my layout.
Oh look! There’s a car I forgot to bring in…over there on that siding!
TonyWalsham said:. You should be able to set up some sort of IR detection inside a tunnel.Bob McCown said:. The range should be OK as long as no daylight gets into the equation. Infra red does not work well in daylight. Fantastic range at night. .
Anyone know the effective range of a photo transistor/irLED pair? Would I be able to use it over a span of say 10" to detect a 1:20 train in between? .
Tony, how much shade does one need? Would a laser work, or even be practical?
These are the musings of someone who is electronically challenged.
madwolf
What I need the IR (or other) detection for is for switches. I can detect cars on regular track no problem, but most of my switches aren’t electrically isolated rail to rail, they’re one big circuit, so I cant detect that way. I was going to use some sort of ‘car-in-the-way’ circuit to detect whether a car is over the switch or not, but I need a range of 8-10 inches. Hmm…
How about shading the IR led and reciever with a shield? or lack of voltage on a solar panel under the track when a car is parked. Yard lamp over it at night.
I also saw somewhere a short brass tube with a very light wire inside, insulated at the bottom. With the light wire protruding from under the track an axle would brush them together completing the circuit.
Bob McCown said:I seem to remember reading some years back about a home-built system where the emitter and detector were mounted in black plastic tubes (I forget the length) to keep stray light to a minimum. The system did require careful lining up. It wasn't outdoors, either.
What I need the IR (or other) detection for is for switches....I need a range of 8-10 inches. Hmm...
