The 2 track receiver does have an add on option for controlling some features and Star hobby had several of these.
Aristo memo on programming the old Xmitr/rcvr:
Aristo-Craft Trains Internet Depot TECH SUPPORT
Linking your Train Engineer Transmitter to the Receiver
This sheet will teach you how to program your ART-5470 Remote Control Train Engineer System for successful control of your trains.
This is achieved by “linking” your hand-held transmitter / throttle to the receiver.
With the Train Engineer system, you can control two separate tracks on your layout from one transmitter!
Please read further down for more information about how to do this.
HOW TO LINK
First, on your transmitter, select track #1 or #2 position.
Then, simultaneously press the A & B buttons.
A flashing light will appear on the transmitter.
Continue holding for 5 seconds.
Then, release the A & B pads.
WITHIN 10 SECONDS…
Simultaneously press the FAST pad on the Transmitter (* please see Notes) and the CODE SET button on the Receiver,
until the green flashing light appears on the Receiver. Continue holding for another 5 seconds. You are now linked. You may release both key/buttons and begin operation of your trains.
NOTES
- Any of the function pads on the Transmitter may be used to link the Transmitter to the Receiver, ie:
A. Track #1, Fast and Code Set.
B. Track #1, Slow and Code Set.
C. Track #1, FWD and Code Set and so, on and so on all the way up to the E button.
This also applies to programming the Train Engineer in the track #2 position.
- If your train requires more than 3 amps, it is highly recommended that you purchase a 12V cooling fan to attach to the receiver.
