Funny you mention this. I am in the process of Devoning a rolling cart that will be the “Cart of Shame” that will hold all my unfinished projects out in the open so they can look at me with their pitiful eyes and beg to be finished. I have resolved to clear out the current “Box of Shame”. And while I would be lying if I said I won’t start a new project before finishing the old ones, I am currently working on two of those pitiful orphans. One is a secret project I started a year ago that is seeing some rapid progress and then the STMA chop nose GP9 is seeing progress as well.
And on another note, after those two are finished then I think I am going to break out the shelf queen 2-6-0 that was my introduction to LSC but that I could never get to run right, and with the aid of 3D printing giver her a new properly aligned chassis. I was lookng at it the other day and I am positive with the aid of my new 3D printing skills can rebuild the chassis to much better tolerances and that will keep the drivers from wanting to reverse. That is the only issue with her. The existing cobbled together front frame section was just to sloppy and imprecise and it was not keeping the front driver properly quartered and it wanted to try and reverse. I think I can print an entire motor block/chassis using the Bachmann motor and drivers and then print some better one piece side rods and fix the entire problem. So you may see that back on the table very soon.
to figure out a way to proceed - or you need to let technology catch up, or you just need to develop new skills.
