Balancing chargers in general are far superior to the basic Smart chargers referenced above. The so called low-end SMART chargers are essentially nothing more than low cost linear battery chargers, simplicity, wider voltage tolerances together with inefficiency and potential for excessive heat dissipation ring true. Furthermore these chargers RELY on the batteries onboard PCB/PCM’s charge current shunts and sensitivity to terminate charge albeit not accurately, whereas these chargers offer a system level specification of ±1% final battery voltage to terminate without benefit of elapsed time limits, temperature and other desirable secondary termination attributes (± 50mV of final battery voltage is typical with real Smart chargers).
The low end Smart chargers also fall short of fully charging your batteries. Undercharging by only 100mV nets a 10% loss of the battery capacity. For this reason, accurate control of the final charging voltage is desirable if not mandatory of Lithium chargers. FWIW some cells are rated at 3.6V while others are rated at 3.7V which exasperates the aforementioned under charged phenomena.
All that said these low end Smart chargers suffice for the masses and are easy to operate. There are caveats though as noted in the descriptions of said chargers such as DO NOT USE THIS CHARGER WITHOUT BENEFIT OF BATTERIES WITH INTEGRAL PCB/PCMs. Additionally some sort of line voltage timer to limit overall charge time would be desirable offerring a secondary charge termination feature.
The aforementioned Tenergy balance charger offers many desirable benefits as compared to the low end chargers. This charger can be used without benefit of the integral cell charge/discharge balance feature same as any other charger.
Michael
