John Bouck said:All battery chemistries have pluses and minuses. Lion has a very high energy density but is finicky about charging. NiCads can be prone to shallow charging if incorrectly charged, etc. NiMHs are not without problems however they have a very nice flat discharge curve, are very easy to charge and can be trickle charged almost forever if properly current limited. The big down side I see to NiHMs is the slow charge time ( 14 hours at 0.1C) and a fairly high self discharge rate.
I'm still on the fence on this one. I started out with Nicads. They worked fine for about three years, and started to fail this year, with only 10 or 15 re-charges. Now I'm experimenting with Nihm's, but on my first year, with excellent results. I have three sets of Liths (or whatever they are called) and can't report on them, either, other than they run a train for a long time. But take a reeeely long time to re-charge.
We selected the NiHM chemistry as our battery for TrainUPS because of the flat discharge curve and the charging characteristics. Since a TrainUPS battery pack rarely discharges fully (we’re using track power maybe 80% of the time) a slow recharge overnight is fine and since we recommend that people leave the loco on powered track at all times self discharge isn’t an issue because we’re always trickle charging (floating).
We’re using the battery for supplementary power, not prime power. Since the battery comes up essentially instantaneously when track power drops off due to crud on the rails (Schottky diodes are fast) you never see a glitch or a dropout on dirty track but you’re still mostly using track power. I’ve been doing this personally since 2004 and as part of our business since we started it back in 2008. We get about 2 years out of a NiHM battery pack before the pack gets ‘shallow’. That’s with 24x7 charging and daily operations. At about $30 per pack that’s pretty cost effective in my book. And the battery pack small enough to get into to road units without using a trail car. We put one under the short hood of an RS3, two of them into an SD45, etc.
I guess what I’m really saying is that I’m a track power guy who hates the hassles of track power, like track cleaning and reverse loop wiring, so I developed a system to get around them.
As to facts about the batteries, I agree, we need to keep the discussion fact based. Our battery data sheet is here http://www.iptrains.org/mediawiki/images/c/c2/2300mah.pdf and I believe it bears out what I claim for the battery.
