Ted, Michael, LSC Members,
Just spoke to Navin for about a half hour and he said to let you know that there were 5 versions of the Dash 9/SD 45 drive and the second version had 12 volt motors.
He doesn’t understand why but thinks it could have been a mistake in China. He says that it doesn’t really matter that much, except for the fact that you can’t over stress the drives with 12 volt motors or they can overheat and burn out, especially with high power transformers. He said the solution to the version 2 drives is to run 2 or more locomotives together on long trains, sharp curves and grades. He says to tell everyone that there are no more Dash 9 motors as he has either given them away or sold them.
He says you can run the 24 volt and the 12 volt motors in the same drive but he doesn’t know the long term results. He does know they will work together, however, it is better, if possible, to at least have matching motors in each separate drive. So it is OK to have 1 drive with 12 volt motors and one drive with 24 volt but he doesn’t know long term (even though they run great together) how good it is to have a mismatch of 12/24 volt in one drive, although a lot of people have done it with no problems. As mentioned above though you can’t over stress locomotives with 12 volt motors by pulling heavy grades, sharp curves and/or to long of a train.
He says, the newer Dash 9’s and SD 45’s have the 24 volt motors (as did version 1) and the problem is there is no way to tell which versions are #2 or which are newer without disassembly and motor winding tests or by a visual observation of the motors that actually say they are 12 volt. (because it is not printed on every 12 volt motor they used)
He says that the Canadian locomotives are all supposed to have 24 volt motors.
So now we have to get motors from outside sources for these locomotives, however, Navin still has gears, gearboxes, screws, washers, springs, ball bearings, axles, wheels, mounting screws and full drive assembly plastic boxes available.
I didn’t ask about other items like electronic boards, switches, lights, handrails and other cosmetic parts but I have a feeling were on our own for most of that.
Hope this helps.
Ken
