Correction Greg,
Aluminum is quite conductive, just not as conductive as copper or brass (but far cheaper). It is the OXIDES that are not conductive. And considering that aluminum begins oxidizing almost immediately when in contact with air (more specifically the oxygen in air), therein lies the rub of aluminum as an electrical conductor, ie. rail. When one finds a method to keep aluminum from oxidizing that is as conductive as the base aluminum, and is economically viable all this hoop la about aluminum rail and conductivity will go away.
Anodizing is a process to hasten the oxidization process, so of course it will not be conductive. Scrape the oxidized layer off the anodized part and see how well it conduct electricity.
As for coefficient of friction, I should hope that it oxidized aluminum rail would have the best tractive adhesion. Oxides of aluminum are very hard and coarse. For those interested, go you your local Harbor Freight and look at their ‘air eraser’ (an air brush sized blasting outfit). The material provided as a blasting medium is ‘aluminum oxide’.
I pose a question to you Greg. IF aluminum is such a poor conductor, why then is it the preferred conductor for our power utilities on all the long distance high voltage power transmission lines?
