The two armed bandit is working along. 1 arm has the airbrush and the other has the hairdryer. This photo was the brush paint attempt the other night when I had all but 10 minutes to work. Gave a nice starting layer to airbrush on top.
Well I think I might be done with the air brush.
There’s a few touch up spots that need some work and the roof needs a new coat of black as I forgot to tape that off.
Hopefully this can all get done tonight and dry well. Then tomorrow I can do some light weathering with a grimy wash and call it done for now.
Craig,
It’s hard to believe I had to basically challenge your manhood a few years ago to join in on this insanity. You are such a great modeler and we don’t get enough of your talent on here. You really are one of the best.
This is looking great. All I wish is that I had taken stock in painters tape. . . I’d be rich.
I don’t have doubts that I can model, I just never think outside the box of projects when I’ve got some stuck in my head.
I’ll say this, my method of siding and roofing with the thin strips might be a pain in the butt to do but it looks great. This might be the swift kick in the butt to do the clapboard siding building of T-D Feeds. I was thinking about doing it with PVC lumber but I don’t have any of that on hand, but I’ve got lots of this thin stuff. I’m sure enough to do one more building.
Yah I should have done the trim first and then painted the rest. Oops. Oh well.
Couldn’t resist mocking up the building outside with the other mockup buildings and half done ones. This is going to be a neat looking scene when it’s done.
Looks great Craig. And after cutting and afixing a billion strips, I have to agree. I am pleased with the results on my project
Despite the 24 hour extension, I’m going to have to call mine done for now. Got thinking about it last night as I don’t want to glue the windows in quite yet until the interior is finished just in case I somehow need access through the windows. I might just start working on the interior next.
Some shelves with random stuff on them, some drop lights, a cash register. Not sure exactly. Probably would be smart to throw in a figure or two.
Or just add this to the list of half done projects.
So it’s been a couple of years since I started the Pawn shop building as part of the MIK challenge and at the time I had the grand idea to try and whip out both buildings but I never had the time nor energy or a method to make the cinderblock building.
Well a few years later, a random trip to meet someone in Everett to exchange/swap train cars, I just happened to make a detour to TAP Plastics and buy a 4x8 sheet of 3mm PVC board.
With that on hand, I started the tedious process of scribing cinderblocks…
During this past 2 years I also was able to acquire slightly more information about the building including the lean too. It has a small man door and a roll up garage door.
While I was at TAP, I raided the $1 scrap bin for acrylic scraps… I then used a piece for the door and window sections and MEK’ed styrene to make the windows.
I’ll probably use the acrylic for the other buildings as well.
Glued a roof and front sign area…
This basically forms the main structure. For the small 20x20 lean to on the backside, I bashed that up with 1/8 styrene, covered the walls with some .030 scrap to represent the plywood sheets they used to cover. It looked from the photo to be a slightly non air tight siding work, so I built in some sloppy 4x8 sheets. I’ll probably slightly sand them to get a bit of texture.
Next up is making shingles once again for the lean too, and covering the flat roof with the concrete patch stuff like I used for the other building.
One of the things I’ve discovered in scratch building is that you end up building it and then in the process you add more and more details as you study the photos. And ironically one of these things I’ve noticed in the process is I end up adding onto the buildings almost in the same way the prototype does.
So I thought I was reading for painting and as I studied the photos more, I realized the aluminum facade was on both the front of the building and down the entire right side and it looked like there was a brick firewall added on the left side to protect the adjacent building.
So now I’m adding them… Both appear to have some sort of metal siding covering them, so the plan is to bust out the paper crimper aluminum cans and caulk them on.
Now off to measure the other building on the block to get an estimate of how far up the brick fire wall goes. The auto repair shop is one of the few buildings I don’t have any information from the tax assessors office on.
It’s a very very slippery slope my friend.
I’m calling this one done. Interesting learning curve with foamed PVC. It definitely has its uses but I like 1/8" styrene better for building with.
i love it. not one, not two, but three links in a post, that are password protected.
Fixed it Korm. Image files where wrong.
I have 3 levels of painting and detailing, 1st is basic finsh, which is fully painted and lettered. Since I use mostly gloss paints i also call it “like new” paint. 2nd is layering the 3 colors for grime, rust and dust with a coating of flat finish. 90% of my models are at this stage. 3rd I’m experimenting with, it additional colors for rust and dust, plus alot of additional details and “character”. That last term being harder to define. Basically until I like it.
Interesting development today I noticed after about a month of exposure…
The styrene shingles have warped/bubbled.
I have two theories on why
- Styrene strips didn’t fully bond the the 1/8" thick frame.
Or - I painted too soon. Either the paint or the styrene needed time to off gas and by applying a clear coat right away it sealed everything in.
Some experiments are in order to see what caused this to prevent in the future. Because of the random nature of it, I’m leaning towards theory number 1. Too many other things to work on so I’ll fix this during the rainy season.
Sorry to see & hear that, Craig. I notice that different areas are reacting differently. Some warping in almost a bubbling fashion; some lifting up; and some behaving fine.
Can you think of anything done unevenly, such as application of solvent? E.g., were you using MEK, and might it have flowed unevenly to lower shingles?
Also, to your #2 theory, perhaps some styrene was still in a solvent-melted condition when the clear coat was applied?
Another question: on the shingles that are lying flat, are they fully bonded to those beneath them, or not much at all? I’m curious as to whether their flatness is due to complete bonding (and being prevented from warping), or due to being free from whatever is causing the warping.
I’m guessing the MEK didn’t flow evenly even though I applied each strip individually and soaked them. I think on the other big building, after the roof was all done, I then tipped it upside down and ran MEK under each of the shingles.
Once I poke around a bit with it I’m sure I can figure out the problem. But I’m not going to worry about it at the moment. Winter project. Trying to focus on getting the rest of the backyard done currently.
So I’m kinda lost here and I “DID” scroll back and re-read. Is this styrene or PVC board or a combination of both?
