I told a friend I’d convert his three Chas Ro passenger cars to battery power. That meant replacing the power for 20 very small incandescent bulbs (E-5 in the trade). I decided that replacing the lights with LEDs would be a good idea, and even better if I could find screw in LEDs. A search of the web turned up exactly what I needed: E-5 LEDs, operating from 6 to 12 volts.
So I ordered them, and while waiting for them, I removed the track pick ups, installed cables between each car, and painted the inside roofs white to reflect some of the light. I also added a single light from an expendable car into the baggage room.
When the LEDs arrived (in about ten days), I just screwed them into the sockets, plugged the cars together, and noticed that about half the LEDs didn’t light up. After exchanging a few, and finding out that they DID work, I reversed the power, and the on LEDs went off, and vice versa! So, I took the bottoms of the cars off (again), and reversed the wiring on about one third of the sockets!
Works like a charm. The LEDs should run for a long time with a new 9V battery. While testing everything I used one that had only about 6V.
No pix, because it really wasn’t much of a project.
