I use a lot of paper signs on my models. I find images I like, usually by searching the internet, and download them to my computer. I scale them to the size I want using a photo editing program. I like the simple one included in Microsoft Office the best for simple sizing and color adjustments. I print the image on plain inkjet paper.
I place the image face down on a piece of flat Plexiglas and thoroughly soak it with isopropyl alcohol. I sand the back of the wet paper with a sanding block until it is tissue-thin. The sanding block is the sponge material type used to smooth drywall. It is important to keep the image wet while sanding to keep it perfectly flat on the Plexiglas. If it begins to dry out and lift, simply brush on additional isopropyl alcohol.
Some of the images are used to represent painted-on exterior signs. To create this effect, I drape the wet image over the stone or wood surface and press it in with a stiff-bristled brush to mark the outlines of the individual stones or boards on the image. I remove the image from the wall and carefully cut it into individual pieces to fit on each stone or board.
I apply matte medium to the wall and position the pieces of the image. Matte medium is an artist’s acrylic medium. It is readily available at art supply and hobby stores (Hobby Lobby, Michael’s, etc.)
I use a soft brush to work the image into the surface and coat it with more matte medium. The matte medium goes on milky-white, but is transparent when dry. After the entire image is positioned and thoroughly dry I spray the entire wall with clear flat to seal the image permanently.
For the images that represent paper posters or metal signs, I use matte medium to attach the image directly to the wall without molding it into the wall texture. When dry, I spray the image with clear flat.
