I think I’ve got my photo posting strength back, so here’s more. Painting really brings the beauty out in this model.
The front truck is a New Bright, from the junk box, with LGB 20mm wheels. It is the only truck of a small size I could find. The wood finish is to replicate Burled Mahogany a “Custom Option” in 1928.
Original plastic wheels are still on the truck.
This is the Digitrax install. I used Velcro to for easy removal. The windows will be blacked out to hide the electronics.
The decoder is mounted on Formica as an insulator. Small super magnets keep the tailgate closed. The front seat is also mounted using Velcro.
The cow catcher was a “head scratcher” but finally came up with a plan. The base is K&S 3/16 rectangle box tube. K&S 3/32 rod for the outer and center supports and 1/16 tube for the rest. I have a 300watt Weller gun that makes soldering brass quick and easy. It also works well soldering track outside.
Here’s the Track Inspection Car in action. I had to cut 1/3s off of my poor B-Man to sit correctly. The light is a 5mm warm white LED.
The spare “tire” is not a joke, I was a Boy Scout, so I always go prepared!
Well, now I can sit back and run it!
