Get a piece of good hardwood that is square (or cut it square on a table saw). It should be about 6 inches long. Using a drill press and a long drill just a bit bigger than the pipe, drill a hole through the middle of the wood from one end to the other. Mark the center on one of the sides and using either a hand saw, band saw, table saw cut about 3 inches into the wood from one end. This gives you a slot for the blade that puts it in the middle of the lengthwise hole. This creates the jig for cutting the tube. Clamp the jig you have made with the slot over or across the blade of the saw (power) Make sure the blade comes up through into the top of the jig enough to cut the top of the metal tube. Now push the metal tube through the jig with the saw running - gives you two half pieces of tube. If you use a hand saw, clamp the jig in a vise. Mark the tube down the top center to give you a guide mark. Use you hacksaw in the slot, slowly push the tube through using the index mark to keep it straight. The hand saw is the hardest way, but it can be done.
Good luck
