Traction Tires
So Ken, you must have applied it for a reason, but I guess it was not critical, or a problem went away?
Thanks for the application tip. Do you remember how long it takes to set up? I like the idea of keeping the wheels rotating.
Well, Greg, I got to rebuilding the layout and that kind of took precedent. I did want to see if it helped on the grades any, but unfortunately with the rebuild I didn’t get much chance to run anything, and by the time I had something to run on I had forgotten all about it, till this thread brought it back to mind.
Tell you the truth I can’t remember how long it took to set up.
Greg Elmassian said:
…Do you remember how long it takes to set up? I like the idea of keeping the wheels rotating.
10-15 minutes. Keeping the wheels rolling helps it to keep an even surface.
Sophie
