For the mining experts
Pete;
Perhaps you could use some of the Woodland Scenics small rock molds and Hydrocal plaster pre-mixed with a reddish clay colored powder paint. Once the Hydrocal sets, you could soften some of the harder angles with a file. Kind of leave some of the dust from filing. Use an “El-cheapo” hair spray to hold it in place. Should look pretty much like dollops of clay from a steam shovel scoop.
Just a thought, David Meashey
All great ideas - thanks guys. Sculpy looks like a good one: anyone familiar with the figure classes knows that it can do.
But I think I have to experiment with Jerry’s natural clay first!
Add a wheel on the side for an automatic dump mechanism:
I did not have much luck with Sculpy outdoors here in Virginia - it eventually just crumbled, in spite of the fact that it was painted. Since then, I had switched to Magic Scuplt - it’s a two part epoxy and also needs paint to stand up to UV, but I found out it stood up VERY nicely - no deterioration at all. It was also nice not having to bake the model.
You can find out about it here: http://magicsculp.com/ and it IS available on Amazon.
Edit: Add the web site.
Magic sculpt does not need paint to hold up against the UV’s. Because of it’s makeup compound it is COMPLETELY durable to the outside elements.
I have been using Magic sculpt for many years outside, with no effects except the paint does not stay bright with out a UV protector yearly.
IMG_3904 by Dennis Rayon, on Flickr
Anyone have any of these Trail Creek kits on their shelf ? Now to figure out how to weather them. The loads can come later.
Weathering tests. I had a couple of planks left over (one kit had 12, not 9,) so I wiped a 50-50 ‘zinc’-colored acrylic paint and water soltuion over them. The RH plank got an extra brush of undiluted paint on top, to see if it looked like clay residue! I think a 50-50 wash with a slightly darker shade of grey will work well. Then some more paint on the bottom of the tipper box where the clay would be.
I went outside and collected some sandy dirt from our path, which I think will do for bits of dirt left behind.
The dirt rub is exactly what I was going to suggest. The right hand plank with the extra zinc looks best for sun weathered wood. I’m not familiar with using zinc. How do you purchase it?
Ah but you are in New England so anything that looks like driftwood is right for you. (http://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-foot-in-mouth.gif)Not that I disagree, but I am more used to black coal dust weathering from PA.
I wondered if I should add a description. It’s regular acrylic paint from Michaels Crafts, a “zinc” color.
I slapped a lot of dilute grey-black paint on the clay tippers this morning. Came out a bit darker than I intended but still fine. The ‘dirt’ is an added mix of sand+glue+paint pushed to the corners with a brush and then swiped out with a rag.
Then why not weather with coal dust from PA?
Because this is not an EBT car from PA. It’s a clay tipper from Georgia. Stay with the program, Roos…
(https://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-wink.gif):giggle:
LOL…SORRY …Then why not weather with clay dust from Georgia? PA has some great clay dust but I bet Georgia’s is better!
Enjoying and following along even though I don’t even like the steam era!
(https://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-cool.gif)
Today was my first chance to run the tippers on a railroad, in this case the SC&M of Naptowneng. First the Mighty Mac took them for a spin while my shay built up some steam.
Then the Shay took over. (The little bulkhead flat was/is also a Trail Creek kit so I loaded it with ties going back to the quarry for track repair.)
Finally, Jerry decided it needed some loads, so we put the dried clay (used for baseball diamonds) in some of the tippers. He also found some stones which bumped themselves to the unguarded side and kept trying to fall out.
Now I have run out of space again on my shelves, so I guess these will have to go. Anyone want a bunch of tippers?
Infield clay
Perfect.
Those look great Pete!
