Flatcar Project
Bob - Looking at the photo I see the holes for the pins in the center sill beams. If you put two pins in each in stead of one it will be considerably stronger with out adding the steel bar. The single pin acts as a pivot in the joint, two pins act as a lock.
If you are going to add the steel bar as described, I would assume you are going to notch the needle beams to allow the bar to sit flat on the center sill beams. And with that you might consider drilling and tapping the steel bar at the truck pins and slipping the bar below the boss for the truck mount.
Yeah, I know … “Where were you when the paper was blank?”
And how much electricity for 26 hours of printing ? (http://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-embarassed.gif)
Awhile back I used a P3 Kill-A-Watt usage monitor to measure. About .11kWh or about a penny an hour to print.(https://largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-laughing.gif)
Ref: https://largescalecentral.com/forums/topic/27877/quick-sunday-afternoon-project-wood-chip-hopper-extension/view/post_id/356065
Do you factor in electrical use when you use a soldering iron, or a lamp on the workbench? These things aren’t mining Bitcoin…
Don’t know about others but I use my soldering iron for minutes usually and have an idea of how electricity is sold. I’ve been soldering for 50 years and using lights longer. but I have no clue about 3D printing and knowing it’s electrical requirements gives me an upfront on its affordability. For all I know it takes 600 kilowatt hours to create a builders plate. So I appreciate knowing that’s not the case
It costs me more in beer than electricity to 3D print.
