Dave -
Point taken. I’ll have to take another look to see where I can fit something in. I decided when I rebuilt the grade and installed the wye that I would try to use very wide curves outside. If I stick with this ‘rule’ it limits the places I could fit a loop within the current track area. R1 would fit inside the legs of the wye.
Once I get past the front steps I have a few large open areas that are pretty much a blank canvas.
There is is one spot I might be able to fit something in. I was planning on someday making a cut off toward another basement window where I have a crawl space. It would be a perfect location for storage yards as it is accessible from indoors at about shoulder height. I’ll have to draw it up to scale and see if I could fit something in there.
I also have the back yard where I’ve considered building on benchwork. The existing track follows a retaining wall across the back yard before it turns toward the front. I could build benchwork out from that wall starting at about 40" from the ground. My knees aren’t what they used to be, so they would appreciate the elevated track.
In the short term, I think the small industry siding will be the next project to be built. Right after I finish the 5 things I started in the spring :o
JR
