Got to work on the roofs.
Started by making a card stock templet,
Transferred the pattern to 3mm Sintra board, cut, and cleaned the edges. Wanting to keep a single piece, with out a seam, I “V” notched the centerline so I could get a clean bend without breaking.
Fitted up to the roof supports, Glued and then used Rubber bands and heavy weights till it dried.
As These are to have a Metal “Murphy roof”, I laid out the joint covers, and glued to the roof.
Next up was the roof walk supports. I had these castings from previous builds.
And then the Access walks bases.
And the roof walk boards test fit.
Well its about time to put some lipstick on these pigs. First will be the roofs, before the roof walks, so I get good coverage under them.
