  • Topic: Taking the Plunge - Li-ion
    Back To Topics
    (0 rates)
    • January 4, 2020 7:00 PM EST
      • Reedley, CA
      • Posts
        417
      • Thanks
        6
      • Thanked
        43
      With most of my NiMh batteries starting to poop out on me I've taken the plunge into the world of Li-ion.  Just purchased two 6700 mAh from RLD to run in my Shay, and in a trailing car I'm still working on.  I've also purchased a Tenergy TLP4000 charger.  I need to do some modification on the batteries since they came with different clips than the 5.5mm x 2.5mm barrel plugs I'm currently using.
      The charger says it is for 1-4 cell...not sure what this means.  And I'm having a hard time finding the answer...perhaps I'm asking incorrectly.  But the two batteries I purchased are the brick style with 8 cylinders...Does anyone know how many cells this is??  And, will this charger work on these batteries??
      I've researched this forum and it seems that there is information from as far back as 2011...so not sure if there is a huge change in technology.  Bottom line I'd like to become better educated with batteries and charging them and am looking for an "Idiot's" type guide with pictures...
      Thanks,
      Richard
    • January 4, 2020 7:12 PM EST
      • Deer Park, Washington
      • Posts
        12,542
      • Thanks
        550
      • Thanked
        346
      Following.
    • January 4, 2020 7:37 PM EST
      • Columbia, Maryland
      • Posts
        230
      • Thanks
        43
      • Thanked
        40
      Richard, the cylinders are indeed the cells. Each one is a singular battery that is wired up with the others to be a certain voltage and milliamp capacity. I have charged an eight cell battery pack with a charger that is only rated for 1-4 cells, and it seemed to do fine, although it did take a long time to charge.
    • January 4, 2020 7:56 PM EST
      • Penacook, New Hampshire
      • Posts
        200
      • Thanks
        0
      • Thanked
        34
      Hi Richard, you have the correct charger for those pack.  With lithium packs there are two values you need to understand.
      1. Total voltage. 4 cells = 14.8V.  Each cell is 3.7V x 4 = 14.8V
      2. mAh is Milliamps per amp hour. 6700 milliamps = 6.7 amps. I believe your charger has charge rate of 1amp per hour then expect it will take 6-7 hours to charge these packs.
      In actual use it will probably take less unless you completely run them till they stop. It is okay to charge them after each run.
      Because these are new lithium packs you should run them till your train stops. It takes three complete cycles for the pack to achieve it full runtime.
      Don Sweet
      RCS of New England
    • January 5, 2020 12:57 AM EST
      • Be Nice or STFU
      • Posts
        9,230
      • Thanks
        238
      • Thanked
        833
      the 1-4 cell rating is for how many cells are in series... but many packs have batteries in parallel.
      putting cells in series raises the voltage, as Don said number of cell IN SERIES times 3.7 volts will equal the nominal pack voltage.
      Battery packs can have cells in parallel ALSO. 4 cells total in series is a 4S1P pack.... 4 Series, 1 Parallel....  if the cells are 1 amp hour capacity, then you would have 4 x 3.7 volts and 1 x 1 amp hour capacity.
      The 8 cell pack is most likely 4S2P, 4 cells in Series, and 2 cells in parallel,  4 x 3.7 volts total and 2 x 1 amp hour capacity, or 2 amp hours (2,000 milliamp-hours).
      Chargers control the charging voltage to match the number of cells in series.
      Chargers can also control the amps, but some just have a maximum rate, so a 4S2P pack would take twice the time a 4S1P pack would, if it was charging at maximum for each.
    • January 5, 2020 4:33 AM EST
      • Bundaberg, Queensland Australia
      • Posts
        332
      • Thanks
        11
      • Thanked
        63
      This may be a useful reference to help new comers with the terminology quoted by manufacturers.
      Simple and effective use of diagrams, there are tabs for charger selection but they may overwhelm newcomers but be useful for more experienced users.
      All in all a reasonably useful reference tool.
      https://scriptasylum.com/rc_speed/lipo.html
    • January 5, 2020 10:30 AM EST
      • Fort Myers Beach & Annapolis, Florida & Maryland
      • Posts
        2,298
      • Thanks
        74
      • Thanked
        354
      Richard, what you didn't tell us is the nominal voltage for the 6700 mah packs.  RLD sells four packs rated 6700mah ranging from 14.4V to 22.2V.
      As you will have gathered by now, LiPo or LiIon cells are rated 3.7V  so a 22.2V pack is at least 6 cells in series. 6700mah is a big number for one cell. If each battery is rated 3350mah (more likely,) then 6 LiIon cells in series will provide 3350mah at 22.2V and 2 sets of 6 batteries in parallel will supply 6700mah.  As Greg says, a 6S2P pack.
      Note that, unlike alkaline cells, Li batteries vary their voltage with the charge state. LiIon and LiPo cells have a protection circuit that cuts the power at about 2.2V to prevent over-discharge, and at 4.25V to prevent over charging.  The 3.7V is a convenient middle ground - but the 22.2V pack could be providing 6x4.25V (25.5V) when just fully charged.
      14.4V is a more common power pack for Bachmann locos, and that is 4 cells.  I have  Tenergy charger and it doesn't automatically work out the battery pack type - you have to set it to a charge voltage (e.g. 14.4V).
      This post was edited by Pete Thornton at January 5, 2020 10:36 AM EST
        Pete
    • January 5, 2020 11:27 AM EST
      • Be Nice or STFU
      • Posts
        9,230
      • Thanks
        238
      • Thanked
        833
      The RLD packs do not have the standard nomenclature published.
      There is a 14.8v 6700 mah pack, 4s2p
      18.5 at 6700 5s2p
      and a 22.2 at 6700 looks like (of course) 6s2p
      also people "play" with the nominal voltage... for years it was accepted the voltage was 3.6v per cell, now people calculate 3.7...  the "fully charged" voltage can be higher, but comes down to 3.7 per cell after running it for a few seconds. All these are the same really.
      Also, the max charge voltage is subject to some variation, but generally accepted to be 4.1 or 4.2 volts per cell, and this is the rub, since that voltage depends on the manufacturer. Set this wrong and you damage your batteries very quickly.
    • January 5, 2020 12:45 PM EST
      • Milpitas, California
      • Posts
        529
      • Thanks
        167
      • Thanked
        53
      Richard, I just bought two Airwire 14.8V 6800 mAh Li-on batteries for two of my USAT GP-9's and I have the same Tenergy TLP4000 charger as you do to charge them. The combo is working out great for me. I get around four hours of charge/run time, and you should be fine!
    • January 5, 2020 12:56 PM EST
      • Elverta, CA
      • Posts
        394
      • Thanks
        3
      • Thanked
        58
      Richard,
      The OEM cell specification data sheet tells the tale. I’d go therein and ascertain what the specific cell(s) in hand require for charging needs. This will very from OEM cell manufacturer, cell capacity and the specific cells in play
       click on link below:
      https://cdn.shopify.com/s/files/1/0697/3395/files/LGChem_icr18650f1l_datasheet.pdf?8595214432028904947
      I suspect the 6700mAh battery you mention is assembled with LG Chem’s #INR18650F1L, 18650, 3.63V, 3350mAh cells.
      Your 6700mAh battery with “eight cylinders” (cells) suggests you have a 4S2P battery. Said battery is comprised of two sets of four cells wired in series netting 14.52V/3350mAh each. The two sets of four cells are wired/connected in parallel and become the aforementioned 4S2P 14.52V, 6700mAh battery.
       click on link below
      https://batteryuniversity.com/learn/article/serial_and_parallel_battery_configurations
      If I’m correct on the cells in play, LG’s INR18650F1L is nothing special or a low yield battery as compared to other 18650’s. STD. discharge rate: 0.2C/0.65A. MAXIMUM discharge rate: 1.5C/4.875A.
      Your 4S2P 6700mAh battery will discharge at 4.875A x 2 = 9.75Amps. Discharge time will be greatly influenced at this level, maybe 20 minutes in my experience with similar cells.
      The charger you note is inadequate if you follow the OEM’s standard charge specification. Trinity states MLP-4000 1 Amp Smart Charger is designed for 1-4 cell batteries. In other words, it will provide 50% of LG’s specification for charging their cell(s) i.e., Std charge rate: 0.3C/0.975A. MAX charge rate: 0.5C/1.625A. Anyway, the charger will work but will slow charge your cells in this configuration, which is NOT recommended by OEM’s.
      OEM’s of Li-Ion/Li-Po batteries generally recommend a MAXIMUM charge cycle of 3 hours. There is NO need to cycle or exercise said Lithium batteries prior to use. These cells have been engineered to be charged as often as desired from any state of charge or discharge. Discharging these batteries should be keep to a minimum to realize a good life cycle. It’s universally accepted by all OEM’s that running said batteries to voltage cut-out (2.5V) is DETRIMENTAL to the battery’s life span. In laymen speak; charge as often as you like when utilizing the batteries, discharge as little as possible between recharging.
      Michael
      This post was edited by Michael Glavin at January 6, 2020 6:39 PM EST
    • January 5, 2020 7:08 PM EST
      • Be Nice or STFU
      • Posts
        9,230
      • Thanks
        238
      • Thanked
        833
      As a side note, it's amazing that people "in the business" still recommend charge cycling lithium batteries like old nicads....
    • January 6, 2020 6:11 PM EST
      • Elverta, CA
      • Posts
        394
      • Thanks
        3
      • Thanked
        58
      Greg,
      Misinformation abounds in the train battery world… Accurate information, facts/specs about Lithium Ion 18650’s is readily available (online). Unfortunately, its ill received, much like hitting a wall of disbelief and or closed doors. Much of our heard of battery-operated train enthusiasts is very partisan, objects and places more credence in the local joey’s and battery/charger resellers with nary any experience and or knowledge thereof. I’ve shared my thoughts and made assertions that are supported by 20+ years’ real-word experience with said cells together with the OEM cell specifications. No heresy here, yet those that should know turn the page and continue to espouse misleading and inaccurate information!
      On the occasion that someone comments with nothing more than heresy and then conversely ceases to engage in productive conversation or dare I suggest debate finds me at a loss. I was thinking as I’m scribbling my thoughts that this seems all too familiar of late. Fake news has many lives…
      Michael
      This post was edited by Michael Glavin at January 6, 2020 6:12 PM EST
    • January 6, 2020 6:36 PM EST
      • Posts
        13,286
      • Thanks
        1,073
      • Thanked
        726
      Michael - Your battery posts are always appreciated. I have learned a ton from you; and thanks to that knowledge some of my oldest on-board LiIon packs are still going strong.  The number one lesson learned: Don't wait for the loco to quit running; charge after a few uses or about 80% of expected charge life.
      www.cvsry.com www.cvsry.com
    • January 6, 2020 6:48 PM EST
      • Be Nice or STFU
      • Posts
        9,230
      • Thanks
        238
      • Thanked
        833
      I agree with Jon. What is interesting is that when given data that might not agree, some people get mad and threatened, as opposed to "hey, I did not know that, can you explain further"...
      I would think to preserve the investment that would be my top priority. You would love the controversy I am embroiled in with someone wanting to recharge lithiums in a car/loco rolling over the railroad, resetting the charging logic every few milliseconds, when I warned of resetting the charger and dumping more charge into a fully charged battery, the response was that the blue charging light was not on, and it descended to name calling and personal insults the next response.
      I should have just given up and sent the gentleman a fire extinguisher.
    • January 6, 2020 6:59 PM EST
      • Posts
        529
      • Thanks
        167
      • Thanked
        53
      Sent who a fire extinguisher, Greg? And would you be specific as to who got mad and felt threatened? You looking for one more guy to argue with on the board? Is that what drives you here, buddy? How come you stopped answering my e-mails and PM's, Mr. 2-Faced? Did I offend you in some way by talking to you directly via PM as opposed to on the board where you can tag-team with Glavin?
      This post was edited by Michael Kirrene at January 6, 2020 7:05 PM EST
    • January 6, 2020 7:20 PM EST
      • Rooster Works "Area 69" ,
      • Posts
        14,286
      • Thanks
        2,290
      • Thanked
        1,380
      How dare one challenge the man behind the curtain! The tin man became so scared he pissed himself and now he is going to rust!
    • January 6, 2020 7:32 PM EST
      • Posts
        529
      • Thanks
        167
      • Thanked
        53
      Now I can see why you two go at it all the time.  Noooowww I see.
    • January 6, 2020 7:54 PM EST
      • Reedley, CA
      • Posts
        417
      • Thanks
        6
      • Thanked
        43
      Ok, gentlemen!!  I don't know any of you personally and I don't wish my original post to be a sore spot for anyone...I'm just a novice looking for some good information to learn from.  And I appreciate all of your comments.
      I charged one of the batteries yesterday and kept rough idea from beginning to end of the charge.  I had 5 hours and 30 minutes when I checked and saw the green light.  Of course it might have been less because was working on other projects and would  check periodically on it.
      Pete Thornton, to answer your question the batteries are 14.8 volts with mAh of 6700.  They are the 4s2p I'm hoping they are strong enough to power my Bachmann 3-truck Shay pulling the 3 AMS coaches at 6lbs each plus the new Bachmann caboose which is also pretty hefty.
      I do appreciate some of the technical stuff but I have to read it slowly to gain the understanding....
      Michael Glavin you said the Tenergy charger was inadequate...do you have a suggestion for another more efficient one?
      Thanks, Richard
    • January 6, 2020 8:07 PM EST
      • Posts
        14,286
      • Thanks
        2,290
      • Thanked
        1,380
      We do?
      I'm been here on LSC and only LSC because I like to model trains as a HOBBY .  However my post took away from Richards original question and I apologize.
    • January 6, 2020 8:09 PM EST
      • Posts
        14,286
      • Thanks
        2,290
      • Thanked
        1,380
      Don Sweet
      RCS of New England
      Thank you Don
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
