My basement hobby room overhead layout is a bit of a hodgepodge. A friend gave ma a 1:1 single red signal light. I repaired it, replaced the bulb with a 12V RV LED bulb powered by a flasher circuit based on a 555 timer, and mounted it beneath the overhead track.
I ordered one of these IR Sensor Switch/Relay
and wired it to turn on the timer. With the delay set for a few seconds it turned the signal on when the train passed and went off a couple seconds after it passed. After about 4-5 cycles now it stays on constantly. When power is applied the relay turns on and stays on. Contacting the seller wasn’t much help. A replacement unit acted exactly the same.
I tried isolating the TX from the RX by placing a short piece of opaque plastic tubing over the TX but no change. I have another unit but am afraid to try it until I know what’s wrong.
Has anyone tried one of these or have any suggestion for troubleshooting?
Harold Wilson
