Aristocraft PRR Steel Long Caboose ART-42104
I have a very dumb question…
So, I picked up an Aristocraft Caboose which has lights and smoke… I run DCC, so I need to do anything special to this car or am I okay to just throw it on the rails and let 'er run? I know nothing about electrical stuff.
Thanks
Steve
What is your DCC track voltage?
(hint, if you don’t know, you should find out, and if you don’t have a RMS reading AC meter, put a full wave bridge on the rails and measure the DC from there and then add 1.4 volts)
Hi Greg,
It’s piko’s dcc system and it says this… “Provides up to 5 amps of DCC power output at up to 27V NMRA DCC track voltage”. This help?
Thx
Steve
Well, 27 volts is probably too much for the caboose accessories. IIRC, there are switches on the bottom of the caboose to turn off the smoke and lights. with them turned off, they won’t burn out.
No, it does not help, because it is probably not accurate, and not a real reading.
I made my best suggestion… since you do not really know what your track voltage is, then the answer is:
if the DCC RMS voltage is at 18v or over, assume your bulbs will burn out (incandescent), and the smoke unit will work great, but watch for overheating and melting plastic.
Your track voltage SHOULD be at about minimum 20v and I run the full 24v.
I believe when mentioning NMRA at 27 volts, this is the NMRA’s way of looking at 22 volts DCC and spec/ing it at 27 volts which really is a DC max voltage.
35010 is 20 volts DC input but 22 volts out??? How do they do that??? And they state 27 volts DCC. I do not believe the writer for the specs understands power at Piko.
The 27 volts DCC is an NMRA interpertation of a sine wave which DCC does not have. PS, most decoders on the market will give real smoke if it is truely 27 volts DCC!!!
35015 booster is spec’d the same way.
On another note… If the input power is 20 volts DC then the output power would only be 18-19 volts due to the input power bridge and the mosfet drivers having a loss.
LGB, Massoth have 24 volt DC inputs to get the 22 volts NMRA spec to the tracck and Zimo has 30 volts input and gets 24 volts to the track.
You get what you pay for!!!
Separately, the piko DCC totals over $800.00, I was thinking at that price it was a good system. Lol
Well, the fact we use 30 volts as an input on the Zimo does not tell you the maximum voltage drop.
In the NCE system, after a lot of testing, it showed that the minimum drop with DC input was 3 volts to the booster DCC RMS output.
Some boosters / command stations with integral boosters have DC to DC power supplies so they can put out a higher voltage on the output than the input.
Bottom line, too much conjecture, measure the voltage.
Or just shut off the lights and smoke ….
B
Brilliant, Sean; simply brilliant…
Fred Mills
My problem would be, I don’t want to…
Jeeze, ignore them, do what I said… then you can have an answer. You should have the ability to measure your track voltage… I gave you a simple method, a cheap meter and a $1 full wave bridge.
Thanks Greg, I’m looking into getting one.
Steve
So, the RRampmeter is really the tool to use, since it can read direct from the track, and when you are not using it to chase down track issues, you can leave it in series with your output and measure DCC voltage and current… but if you don’t want to pony that up, any old DC meter with a full wave bridge converting the DCC to DC will be enough.
https://www.dccspecialties.com/products/rrampmeter.htm
In any case, this will help you stop burning out your bulbs… I first noticed this as I used to leave track power on all the time, with a couple of trains on the track, then I noticed one marker light was out, then another, and by the time I smartened up, I’d burned out the marker lights on a caboose and several locomotives… and as you know, Aristo steam loco marker lights are not sitting for sale on shelves in the local Walmart.
Best, Greg
Thanks
Steve
I’m suspecting you will be just fine throwing it on the rails and let er’ run. However “I personally do not own an ART-42104”. I do believe the others that do “own one and run DCC” already have you covered.
This post has been edited by : Rooster
The lights may burn out and the smoke unit overheat on DCC unless you run lower than 18 volts DCC
Steve said:
Hi Greg,
Thx
Steve
Steve, You are reading this on the Piko America ordering page.
The 27VDCC shown there is either a typo or some misunderstanding.
If you check the manual for the Piko DCC Central Station (which you should really use as reference), it states that the DCC voltage is 22 VDCC regulated.
https://www.piko-shop.de/is.php?id=6353
This is certainly possible - it’s called a DC-DC Converter
However, I doubt that the Piko Central Station is using that type of circuitry.
But if one checks the Piko manual rather than just a sales blurb on the Piko America website, one will see the following specs:
Allowable Input Voltage: 16 - 24 VDC
Total Allowable Load: 5.0 amps
Output Voltage: appro, 22 VDCC, regulated
(translation of the German part - the English translation in the manual is slightly different but the meaning is pretty much the same)
There is nothing wrong with the Piko DCC Central Station that I’m aware of.
Like Greg said, measure the actual track voltage with either a DC meter and a diode bridge like Greg said or buy a RRampmeter
Considering the amount of money one spends on DCC equipment, I think a RRampmeter is a good investment to monitor and troubleshoot.
