I have a 1:20.3 spectrum 4-4-0 and it stopped moving - cracked axle gear, I thought. (I already replaced one on my 2-6-0.) So I ordered the replacement axle from Bachmann Parts and got on with the surgery
Imagine my surprise when I realized it wasn’t the axle - it was the first gear pair and the spur on the worm was completely worn away!
For the moment I put it back with a washer to force it to mesh, but that won’t last long, and I’m not sure I can be bothered to put the whole loco back together if I can get another gear.
Anyone know where I can get a replacement? The whole motor/gearbox pair is available, but for $50.40.
The gear looks just like the one on the axle, but different shaft and the extra spur attached to it. Guess I could pin the axle gear to the smaller spur gear and use some brass tube in the hole. . .
I measured the axle gear and it is about 0.62" diameter and 25 teeth, but this one from Bachmann has a flat on the axle so the gear has a “D” hole in it to match. (I think that’s new?) This bad spur/worm gear is 0.60" and 24 teeth. Maybe one of those NWSL 24 tooth gears would work.
