Forums Power and Sound Power and Sound DCC
  • Topic: USA Trains F3 DCC Convert
    Back To Topics
    (0 rates)
    • March 7, 2019 12:40 AM EST
      • Clearwater Bay, Hong Kong
      • Posts
        11
      • Thanks
        0
      • Thanked
        0
      I know there are a few threads about this and some interesting articles on the internet. I was wondering if there was anything new that let you use the original lighting (including the LED that change color). Perhaps using a Zimo 699KV ? Hoping to keep the lights available at all times on DCC,
      Andrew
    • March 7, 2019 10:28 AM EST
      • Kittery, ME
      • Posts
        606
      • Thanks
        40
      • Thanked
        204
      Andrew-
      The challenge with the classification LEDs is that they are common cathode (i.e. common ground), and the Zimo decoder output provides a common V+.  The white/black wires that feed the LEDs on the PCB in the front of the engine expect 12V or more, and the color switches with polarity.  If white is + and black is -, the red LEDs go on, and if the polarity is reversed, the green LEDs go on.
      You could potentially feed these from an H bridge with the polarity controlled by the headlight output, assuming you want the colors to track the headlight/reverse light.
      Of course these red/green classification lights are fantasy, and should (in my opinion) just be replaced with white lights anyway.  A green light means that a second unit of the same train is following.  A red light would only be displayed on a rear-facing engine on the back of a train.  It's hard to imagine an F3 in that situation.  You could easily clip off the red/green LEDs, hot glue some white ones in the shell, and feed them from one of the Zimo's drivers with a CL2N3 in series.
      This post was edited by Eric Reuter at March 7, 2019 12:07 PM EST
    • March 7, 2019 12:44 PM EST
      • Carlsbad, CA
      • Posts
        8,122
      • Thanks
        133
      • Thanked
        621
      What Eric said.
      I have looked for white/green common anode leds to replace the nonsensical red/green ones, I thought I found them once... I would just replace with white, and depending on your railroad, leave them on all the time in forwards, or have them commandable.
      Certain railroads ran every freight as an extra, since they were not part of a regular schedule.
    • March 7, 2019 12:48 PM EST
      • Carlsbad, CA
      • Posts
        8,122
      • Thanks
        133
      • Thanked
        621
      Hmm... maybe I can have some made... at work, so those LEDs on USAT diesels are 5mm leds right?
    • March 7, 2019 2:20 PM EST
      • Kittery, ME
      • Posts
        606
      • Thanks
        40
      • Thanked
        204
      They are 3 mm.
      This post was edited by Eric Reuter at March 7, 2019 2:20 PM EST
    • March 7, 2019 2:59 PM EST
      • Carlsbad, CA
      • Posts
        8,122
      • Thanks
        133
      • Thanked
        621
      I found some common cathode green and white in 3mm ... still researching... I think I'd best just make a small circuit to invert the logic to allow common cathode, can't find the common anode
      This post was edited by Greg Elmassian at March 7, 2019 4:13 PM EST
    • March 7, 2019 4:54 PM EST
      • Kittery, ME
      • Posts
        606
      • Thanks
        40
      • Thanked
        204
      I don't ever expect to run two units of the same train, so I haven't worried about it.
    • March 7, 2019 7:53 PM EST
      • Pittsburgh, Pennsylvania
      • Posts
        10,304
      • Thanks
        86
      • Thanked
        673
      Eric Reuter said:
      ....................... A red light would only be displayed on a rear-facing engine on the back of a train.  It's hard to imagine an F3 in that situation.
      I can see it in a push pull operation, with a F unit on both ends of the train. Or, as in the PATrain, a control car at one end, and an F unit on the other end.
      Shannon car Shops
      Home of the infamous leg lamp
      I.A.R.R.R. Member #12
      and King Butt Modeler
    • March 8, 2019 7:21 PM EST
      • Defending the State of Exile! ,
      • Posts
        13,149
      • Thanks
        1,433
      • Thanked
        958
      Welcome AJ !
    • March 8, 2019 7:26 PM EST
      • Posts
        13,149
      • Thanks
        1,433
      • Thanked
        958
      Never say never.....It's like preparing for Y2K....wait that's over so why not plan on preparing for Y 2.9 and 3/10's K then?
    • March 9, 2019 7:10 AM EST
      • Eastern Massachusetts
      • Posts
        1,030
      • Thanks
        6
      • Thanked
        72
      I would go with negative type logic and for a common anode dual led I would ground the bias resistor on the high side to deactivate the led.
      Just tie the cathode to common/ground.
      The 7545X series of dual drivers would work well for doing this as they are dual opencollector IC chips and 300ma output.  Also great for driving relays on the revolution function keys as a 2ma input will give you a great driving current.
    • March 9, 2019 12:59 PM EST
      • Carlsbad, CA
      • Posts
        8,122
      • Thanks
        133
      • Thanked
        621
      So you would invert the sense, so function on is LED off?
      But my Zimo handheld will be glaring at me with a bright yellow LED !!!
      Yes, using transistors is another option, I looked at that, but I liked the complete isolation of the opto. The opto itself is only 50 cents. for my bicolor led, 2 optos and 3 resistors, simple circuit, solder the resistors to a 8 pin dip wirewrap socket and you are nice and compact.
    • March 9, 2019 6:43 PM EST
      • Port Orchard, Washington
      • Posts
        2,056
      • Thanks
        78
      • Thanked
        162
      Dumb question..
      Why can't you just wire the LED class lights to a lighting function output? Much like ditch lights? Then just control with you throttle? Assuming you replaced the red/green with white.
    • March 9, 2019 10:18 PM EST
      • Carlsbad, CA
      • Posts
        8,122
      • Thanks
        133
      • Thanked
        621
      bicolor led.... 2 leds with a common.  Common cathode is all I can find. Simple answer is you need common anode on DCC decoders, "common" is positive, not negative.
      bipolar would probably be easier, but those are even harder to find. White and Green is an unusual combination.
    • March 10, 2019 1:58 AM EST
      • Posts
        11
      • Thanks
        0
      • Thanked
        0
      Thank you everyone.
      It looks like I might do the simple down and dirty install for now :) and perhaps replace the classification lights with white LEDs
      Andrew
    • March 10, 2019 11:04 AM EDT
      • Carlsbad, CA
      • Posts
        8,122
      • Thanks
        133
      • Thanked
        621
      That LED is a bicolor, bipolar led.... i.e. just 2 leads, polarity gives different colors.
      Different wiring than a bicolor common anode/cathod led (3 leads)
      Check this page, and it has a schematic to control the bipolar, bicolor led with 2 function outputs.
      (you can independently control the red and green colors)
    • March 11, 2019 7:13 AM EDT
      • Posts
        1,030
      • Thanks
        6
      • Thanked
        72
      7545X is only 29 cents at Jameco and has 2 separate open collectors (300ma total), 200ma each output).  And for revos it could drive a smoke unit!!
    • March 11, 2019 8:43 PM EDT
      • Branchport, NY
      • Posts
        215
      • Thanks
        17
      • Thanked
        10
      What Page?
      Tom
    • March 12, 2019 1:30 AM EDT
      • Carlsbad, CA
      • Posts
        8,122
      • Thanks
        133
      • Thanked
        621
      Whoops!
      check this page
      about 2/3's of the way down the page... the stock led in the USAT locos is a bipolar bicolor...
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
