Test 1
What CNC are you using?
Neat!
Basic form is cut on the laser, then finish work is done by hand with carving tools.
2 nd try , it has been a couple years since i have posted pictures here, I always have to relearn this procedures.
Well here it is no picture, this blank blank site
wow it works from Fliker, go figure
Untitled by Dennis Rayon, on Flickr
I lasered the joints and i carve the details with a small hand chisel, the details takes a little time, but well worth it
That is cool Dennis…
I cut the edge joints with a table saw at 48 degress so when assembled the outside edges come together tight leaving me a gap on the inside so I can squirt like a caulk, a joint of Lexel glue.
Thanks Jim
I spray paint with a medium brown aresol . then I use basic acrylic paint from Walmart, The first paint shows the brick painted
with a redish type color. The second one shows the brick highlighted with a white and a black, then lightly wire brushed.
Nice looking stone and brick work, Dennis. Very realistic.
Thanks Dan
That is the reason I like using it, and is quite easy to carve
Very nice!!
Well done, Dennis.
I got a window like that, very good looking, where do you buy the precision board?
Thanks Guys for your kind compliments
