So, I’m in the process of designing my new layout and workshop space in the new house, and I’ve got a design problem, I need help with.
I have 2 sides of the garage to work with for both a staging yard to exit outdoors thru a hole in the wall and a workshop space. The two walls are 90 degrees to each other. The longer wall is about 20’ (depth of a standard garage, minus a exterior door), and the shorts wall is about 12-15’ long. My initial gut reaction was to have the staging along the long wall, thus maximizing the length of available space, but that would require a 90 degree turn from staging to the layout area. That means the shelf that holds the staging yard would have to stick out at least 4’ (so I can have a 4’ radius curve outdoors).
The shorter wall would provide a straight shot from staging to the layout, but that would require reversing (flipping how it opens into the garage) the exterior door (which is fine), but is a much shorter staging yard (12’ vs 20’).
So which wall should the staging yard be on? The shorter wall, or the longer wall?
