  • Topic: Isolating the Motor Pick-ups in a Delton Doozy?
    Back To Topics
    (0 rates)
    • September 22, 2018 1:54 PM EDT
      • Santa Ana, CA
      • Posts
        1,537
      • Thanks
        1
      • Thanked
        100
      The motor block on the Delton Doozy (and my Hartland) is "self-contained" in that when the block receives power, the motor runs and power is available at the external terminals to tie in the front axle.
      I want to isolate the motor from the contacts so that I can shut it off/delay its start when the track receives power.  Has anyone been able to open one of these blocks and make this modification and if so, what did you do?
      Thanks
    • September 22, 2018 4:30 PM EDT
      • Vail, Az
      • Posts
        4,519
      • Thanks
        821
      • Thanked
        698
      Some might suggest calling Phil at Hartland, but first you might dl the pdf they have ..
      http://www.h-l-w.com/doozie.html
      John
    • September 22, 2018 4:48 PM EDT
      • Santa Ana, CA
      • Posts
        1,537
      • Thanks
        1
      • Thanked
        100
      Thanks John, I sent them an e-mail.
    • September 23, 2018 7:03 AM EDT
      • Southern Illinois
      • Posts
        8,824
      • Thanks
        249
      • Thanked
        286
      I think I understand the question.  HLW's are the easiest of all to isolate the power from the trucks.  There is a little piece of piano wire going from contacts to wheels on each truck and the removal of that wire is simple.
      This post was edited by Ric Golding at September 23, 2018 7:04 AM EDT
    • September 23, 2018 2:24 PM EDT
      • Santa Ana, CA
      • Posts
        1,537
      • Thanks
        1
      • Thanked
        100
      Thanks.
      Do you think it would be difficult to run a pair of wires out of the block for a motor contact?  I only need to isolate one side.
      This post was edited by Todd Brody at September 23, 2018 2:26 PM EDT
    • September 24, 2018 5:13 PM EDT
      • Prescott Valley, AZ
      • Posts
        652
      • Thanks
        7
      • Thanked
        42
      Hi Todd......  As Ric shared, the Hartland stuff is very easy to isolate and work with...    If there is a red and black wire going into the motor block, they should be connected to each side of the motor..
      I've converted many of their motor blocks in the past..
      In May 2015, the PCSRR in Dewey, AZ became a Fallen Flag
      But, we're still quite active in the Model Railroading Community and
      still in the decal business.  Please use the contact info
      cedarleafcustomdecals.com
      scedarleaf@aol.com  928.778.3732  or 520.831.3390
    • October 4, 2018 5:24 PM EDT
      • Santa Ana, CA
      • Posts
        1,537
      • Thanks
        1
      • Thanked
        100
      Hartland responded to my email today and said they would be glad to help with assistance.  With the season now over and everything put away, thus inspired, it was a simple matter to remove the body from the frame (gotta watch for those two front scrrews) and remove and open the motor assembly.
      After opening the assembly, I just removed the leads from the motor and ran new motor leads into the body up through the existing pivot hole.  My only problem is that I noted on reassembly that the female screw posts are all broken up, but it seems to hold together OK so far.
      I emailed Hartland and thanked them.
      Now I can slow this thing down (12 volt motor) to run simultaneously with my other stuff as well as add a delayed start so the operator can go through the start routine (i.e., open/close the door, crank the engine three times to catch, idle) before the doozy pulls out of the station.
      Thanks guys.
      This post was edited by Todd Brody at October 4, 2018 5:26 PM EDT
    • October 4, 2018 7:05 PM EDT
      • Posts
        652
      • Thanks
        7
      • Thanked
        42
      Super, Todd.......  The Hartland motors are very efficient and low current draw...  Glad Phil provided the aid...
      Have phun...
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
