So, what if I only had one A/D Track (to piscine loop), then a 3-track ladder with a drill spur (I believe this is also a yard lead, no?). Just a note, the triangle is one of the corners of Piscine Loop, so the train wouldn’t have far to go if it picked up rolling stock on the Piscine A/D if it was ultimately headed south.
Greg, I am going to move the crossover as well. I did find your site and info a few days ago. It’s what encouraged me to modify my yard at all (it was just a classification ladder).
Chris, thank you for pointing out the obvious improvement on moving the points so the A/D track can get to the wye. Really, it doesn’t make much of a difference since, as said above, the loop is right there, but in terms of operating possibilities, it’ll be more interesting. This way I could turn a train around using the wye.
I will redo the plan when I’m home from work and post a photo.
