Forum Sponsorsss
Forums General Operations
  • Topic: Speed Synch
    Back To Topics
    (0 rates)
    • April 3, 2018 10:10 AM EDT
      • Spring Lake, NC
      • Posts
        3
      • Thanks
        0
      • Thanked
        0
      Speed Synch
      Hello, new to the forum.  I am looking for assistance with how to speed synch my Alco FA-1 and FB-1.  The B unit pushes the A unit.       Can anyone help with step by step process for Dummies?  thanks Dana
    • April 3, 2018 11:54 AM EDT
      • Kittery, ME
      • Posts
        668
      • Thanks
        43
      • Thanked
        259
      It depends entirely on how you are controlling them - i.e. DC, DCC, Revolution, AirWire, etc.
    • April 3, 2018 12:33 PM EDT
      • Spring Lake, NC
      • Posts
        3
      • Thanks
        0
      • Thanked
        0
      I am running them off a Bridgewerks Mag Mate 100.
    • April 3, 2018 6:22 PM EDT
      • Be Nice or STFU
      • Posts
        9,220
      • Thanks
        238
      • Thanked
        829
      First, I would suggest "Rebuilding" the motor blocks, i.e. opening, cleaning, lubricating, checking for any problems.
      Then, if one unit consistently runs faster, ad a "voltage dropper": https://elmassian.com/index.php?option=com_content&view=article&id=185:misc-electronics&catid=19:trainelectronics&Itemid=353
      look for the section called "voltage dropper"
    • April 5, 2018 1:40 PM EDT
      • Elverta, CA
      • Posts
        394
      • Thanks
        3
      • Thanked
        58
      Dana,
      What Greg suggested.... I had a friend with a like issue, he simply swapped the trucks to the 'A' unit; so it pulled a little harder than the 'B' unit worked for him.
      Michael
    • April 10, 2018 7:05 PM EDT
      • Spring Lake, NC
      • Posts
        3
      • Thanks
        0
      • Thanked
        0
      Thank you for the responses.  If i can figure out how to do it, the cleaning and truck swap sounds like a good solution.  thanks, Dana
    • May 12, 2019 2:30 PM EDT
      • McLean, VA
      • Posts
        154
      • Thanks
        2
      • Thanked
        18
      Dana - If the motor block swap approach doesn't work well, you may need to replace one or more of the locos' motor blocks.  Replacement motor blocks for these LGB F7A units.  LGB F7B units don't come with motor blocks so apparently you installed one or two motor blocks into it as I did for a customer.  You can find the replacement F7A motor blocks at many large scale hobby stores, such as www.OnlyTrains.com has a good price for about $110 each.
      Tom
      Tom White
      LGB Railfan - LocomotivesPro
      https://www.olddominionrailways.com/
    • May 12, 2019 2:49 PM EDT
      • Be Nice or STFU
      • Posts
        9,220
      • Thanks
        238
      • Thanked
        829
      Tom, you do realize this is over a year old, and the OP only posted a total of 3 times all on this thread?
      Anyway, you can buy replacement motor blocks from Bachmann, through many different dealers. Much better idea in my opinion, bolts right in, matches exactly speed and size.
    • May 12, 2019 3:23 PM EDT
      • McLean, VA
      • Posts
        154
      • Thanks
        2
      • Thanked
        18
      Greg - Okay, I misread the date on the posting, I thought it was April 2019........sometimes happens when I speed read these forums!
      Tom
      Tom White
    • May 13, 2019 3:40 PM EDT
      • Be Nice or STFU
      • Posts
        9,220
      • Thanks
        238
      • Thanked
        829
      The good news is the replacement blocks can be bought... lucky for us that Bachmann decided to revive the eggliner!
    • May 13, 2019 6:10 PM EDT
      • San Mateo, California
      • Posts
        314
      • Thanks
        86
      • Thanked
        128
      Aristo-Craft Motor Blocks
      Tom
      The ALCO FA1 & FB1 are Aristo-Craft products, so "...these LGB F7A units. LGB F7B units..." would not seem pertain.
      The following information may be of help:
      Aristo has/had 2 basic versions of motor blocks:
      The old one is illustrated below.
      See "Remedying factory flaws" within vignette (article), and then Scroll down to "Open circuit / intermittent Truck power pickups" showing the older type Aristo motor block.
      The newer ball bearing type is illustrated below.
      See vignette: "Upgrading Aristo-Craft Loco Motor Blocks from Sleeve to Ball Bearing"
      -Ted
      This post was edited by Ted Doskaris at May 13, 2019 6:29 PM EDT
    • May 13, 2019 8:33 PM EDT
      • Rooster Works "Area 69" ,
      • Posts
        14,276
      • Thanks
        2,286
      • Thanked
        1,373
      Welcome to LSC Dana even if it is a month old welcome!
    • May 13, 2019 9:54 PM EDT
      • Saint Johns, Florida
      • Posts
        4,463
      • Thanks
        469
      • Thanked
        678
      You mean 13 month. Look at the date of his post as was pointed out by Greg.
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
