Forums Power and Sound Power and Sound DCC
  • Topic: Thomas the train DCC module from Bachmann
    Back To Topics
    (0 rates)
    • January 14, 2018 3:20 PM EST
      • Posts
        9,393
      • Thanks
        249
      • Thanked
        861
      I see bachmann sells 2 locos with DCC and specialized sounds, plus a DC/DCC sound decoder separately.
      Has anyone run one of these locos under DCC or tested the DCC decoder? Wondering if they will work on 24v systems, and who made the sound system.
    • January 14, 2018 10:51 PM EST
      • west of Pittsburgh, Pennsylvania
      • Posts
        168
      • Thanks
        159
      • Thanked
        23
      Hey Greg,  I just put together this Thomas loco for my grandson for Christmas.  I bought the basic Thomas, Annie and Clarabelle set and then added the Bachmann #44958 DCC Sound Module.  I used a 14.8 volt, 3350mAh Lithium Ion 4x1 cell battery to power an Airwire CONVRTR-60X.  I was also able to add a small oval 8 ohm speaker.  I installed two switches.  One to switch from a conventional DC track controller or to battery and the other to switch from battery-off-charge.  I added a warm white led for the headlight, a red led for backlight and a small led to let me know that the battery was turned on.  This was all very tight, but it did fit.
      The DCC Sound Module manual says not to "exceed the decoder's input voltage rating of 26 volts. When your track voltage exceeds 28 Volts, the decoder will automatically shut off the sound and motor".  so it looks like it would operate ok on a 24 volt system.  I could not go 24 volts because my Airwire receiver is rated 22 volts max. I ran the engine and two cars  at max throttle around a small loop of track as my grandson would probably do at 16 volts DC and it fell off the curve rather quickly.  So that is one of the reasons why I chose the lesser of 14.8 volts.  The battery was also small enough to fit.
      I was able to adjust the cv values easily for the lighting, acceleration and deceleration.
      That's what I can offer from my experience with it.  I am very happy with it and more importantly so is my grandson.  We can't wait for the snow to melt (yeah, I know, Carlsbad, CA doesn't have the snow) and run it out in the yard.  As for the manufacturer of the decoder I have no clue.  I'll try to send a pic of the finished loco before I closed it up.   Mark
    • January 14, 2018 10:55 PM EST
      • Posts
        9,393
      • Thanks
        249
      • Thanked
        861
      Thanks, what do you think of the sound, and what are the "specialized" sounds that it has? (it has settings for all the Thomas "clan")
    • January 14, 2018 11:00 PM EST
      • Posts
        168
      • Thanks
        159
      • Thanked
        23
    • January 14, 2018 11:10 PM EST
      • Posts
        168
      • Thanks
        159
      • Thanked
        23
      The sound is pretty good.  The speaker had to be very small to fit but considering that I am happy with it.  It has the characteristic whistle sounds (long and short), blowdown and exhaust chuff. Only Toby has the bell.  The decoder comes with all the sounds for Thomas, Percy, James, Edward, Henry, Gordon, Emily, Spencer and Toby.  These are chosen with cv 115.  Mark
    • January 15, 2018 12:32 AM EST
      • Posts
        3,947
      • Thanks
        0
      • Thanked
        74
      Having the weight of the battery pack at the back will make the loco tail heavy and light on the front drivers.
      My experience is that unbalanced Thomas derailed very easily.
      Best wishes,
      Tony Walsham
    • January 15, 2018 9:06 AM EST
      • Posts
        168
      • Thanks
        159
      • Thanked
        23
      Tony,  If we have derailing issues once we get to run Thomas outside I will definitely keep that off unbalanced issue in mind.  Now that you have mentioned that I can see the possibility.   It seemed ok inside on the roundy-roundy setup but outside in the "real" world it may act differently.  If so maybe counter balancing with some weight in the front may help.  Thanks for the heads up.   Mark
      This post was edited by Mark Betlem at January 15, 2018 9:12 AM EST
    • January 15, 2018 11:56 AM EST
      • Posts
        9,393
      • Thanks
        249
      • Thanked
        861
      So Mark, what other stuff comes out of the sound module? There's no description, other than the "bell exception" of how the various "personalities" make themselves "known" with unique sounds.
      Thanks for the responses (oh if you know the dimensions of the board, that's not in the manual).
    • January 15, 2018 2:34 PM EST
      • Posts
        168
      • Thanks
        159
      • Thanked
        23
      Greg,  In the sound decoder manual Bachmann references SoundTraxx for additional information about the automatic sound functions so that leads me to think that SoundTraxx is the manufacturer of the board.  On the back of it's packaging it is stated that the approximate board dimensions are 60mm x 30mm x 15 mm.
      I cannot speak from my experience about the various "personalities" sounds through the decoder since I only set up Thomas.  On the show he does have a distinctive whistle sound which sounds exactly the same through the sound decoder.  I am assuming that by choosing between the various characters  one would get a distinctive whistle for that particular character.  As Thomas starts to move the chuff sound is in sync with the drivers and when he stops the blowdown is heard.  It sounds good.  Now weather or not these sounds are distinctive to the particular character or not, I cannot say.  I hope this is of help.  I definitely owe you one.  Mark
    • January 28, 2018 4:41 PM EST
      • Posts
        9,393
      • Thanks
        249
      • Thanked
        861
      OK, I now have one of the modules, and will be testing out the sounds.
      I have a web page showing the package and the module itself, as well as a link to download the manual:
      https://elmassian.com/index.php?option=com_content&view=article&id=742&Itemid=1200
    • August 13, 2018 2:48 PM EDT
      • Becker, Minnesota
      • Posts
        122
      • Thanks
        30
      • Thanked
        27
      Mark-
      Did you adjust the CV's through DCC throttle/DCC system, or did you use a computer program like JMRI Decoder Pro?
      This post was edited by Eric Warhol at August 13, 2018 2:49 PM EDT
      - Eric
      Greater Minnesota Railroad (GMRR)
      "An Adventure in Garden Railroading"
    • August 14, 2018 7:45 AM EDT
      • Eastern Massachusetts
      • Posts
        1,195
      • Thanks
        7
      • Thanked
        103
      Be aware that Bachmann used the Soundtraxx dcc/sound decoder in the 3 truck shay and it has a 21 volt DCC limit.  Fault condition for over voltage is 10 blinks of the lights.
      All of my systems are 24 volts (yes 24, power supply is regulated 30 volts) and only one was adjustable to go down to 21 volts.
    • August 14, 2018 7:58 AM EDT
      • Chelmsford, MA
      • Posts
        689
      • Thanks
        41
      • Thanked
        154
      Dan
      It is true that when Bachmann released its 3 Truck Shay with sound long long time ago, the Soundtraxx decoder used indeed has a 21 volt DCC limit which shall we say a pain in the butt.
      HOWEVER
      I am aware of NO product that Bachmann has released in Large Scale since then that has this problem.  For example Bachmann has released a LS Climax with sound and a Thomas (Percy) with sound and neither has the 21 volt limit.
      I also believe that no Soundrtraxx Large Scale decoder released since the 3 truck shay that has this problem.
      Manufacturers do learn from their mistakes.
      Stan
    • August 16, 2018 7:35 AM EDT
      • Posts
        1,195
      • Thanks
        7
      • Thanked
        103
      Thanks Stan for that info.  I mentioned it only because I did have an issue with the Shay but when I lowered my system to 18 volts everything worked great.
    • September 1, 2018 5:47 PM EDT
      • Posts
        9,393
      • Thanks
        249
      • Thanked
        861
      Well, now I have been doing some running of an Emily, with the Bachmann "Thomas Family" sound card.
      I'm disappointed... the only sounds are the chuff and a whistle, and a steam blowdown. No bell, except for one "personality" and that one has no whistle.
      But a bigger issue has surfaced. If the power is interrupted for a brief time, the loco stops. It won't go again unless you reduce the speed to zero and then throttle up. You don't need to touch it, just lower the speed to zero.
      Very weird behavior. The Emily has 3 sets of wires for power pickup, but I suspect one set is not working well or at all. Will work on this but this is just a crappy decoder. Too bad, but Soundtraxx has a proven history of "crippling" it's OEM decoders in some strange ways (like leaving the chuff input off).
    • September 1, 2018 9:55 PM EDT
      • Posts
        168
      • Thanks
        159
      • Thanked
        23
      Hi, Eric  I apologize for just responding to your question but for some reason I missed it until just now.  I adjust the CVs through my Airwire throttle.  The Airwire CONVERTR 60X gives me no problems communicating with the Bachmannn/Soundtrax decoder.  I haven't experienced the power interruption problem that Greg has seen but I have this one set up directly with battery.  So that leads me to go along with Greg's thoughts on possible power pickup issues.   Dan,  I use the recommended 14.8 volt battery that Airwire recommends (which is more than enough power/speed for my young grandson) but thanks for the heads up.   Greg,  I agree that the sounds selections are minimal at best but I figured that since this "toy train" really is a being used as a toy (a very expensive toy)  that they were sufficient.  I was hoping to get a bell out of the Thomas "personality" but then that wouldn't be realistic.  Did I just say that? .......bye
    • September 2, 2018 2:37 AM EDT
      • Posts
        9,393
      • Thanks
        249
      • Thanked
        861
      I run 24v on on my layout... the Emily ran close to 200 or 300 scale miles per hour. Setting CV 5 to 100 got things back to being more realistic... oops, I said it too!
      Really strange behavior forcing you to stop to proceed on power interruption. I suspect that not all the power pickups are working well, and will address or add power pickups to the tender, since I want to eventually add lighting fore and aft.
      Yes, under battery you would not see this situation...
    • September 2, 2018 7:13 AM EDT
      • Pittsburgh, Pennsylvania
      • Posts
        11,107
      • Thanks
        125
      • Thanked
        904
      That should make the kids happy. Kids are always asking me if my trains can go faster.
      Shannon car Shops
      Home of the infamous leg lamp
      I.A.R.R.R. Member #12
      and King Butt Modeler
    • September 5, 2018 11:36 AM EDT
      • Becker, Minnesota
      • Posts
        122
      • Thanks
        30
      • Thanked
        27
      Anyone know if Soundtraxx with Tsunami 2 or QSI with Titan E3 have a whistle close to Thomas' peep peep?
      - Eric
    • September 5, 2018 1:39 PM EDT
      • Posts
        9,393
      • Thanks
        249
      • Thanked
        861
      The peep peep is pretty European. The Tsunami list does not have European sounds:
      http://www.soundtraxx.com/dsd/tsunami2/sound/Steam-2_Sound_Selections.pdf
      The QSI Titan has a British Railways single chime that sounds good... it will do a a peep... (you can load the software and listen to it without the programmer)
      Otherwise, a Zimo or other European decoder with more European sounds would be good... you could use the MX645 which is an HO decoder that has enough "umph" for the Thomas type trains.
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
