  • Topic: Does REVO II care which side of the power input is (+) ?
    Back To Topics
    (0 rates)
    • October 14, 2017 7:08 PM EDT
      • Deer Park, Washington
      • Posts
        12,551
      • Thanks
        558
      • Thanked
        356
      I'm doing my first battery onboard REVO II install, and intend to tie the battery into the board at the point where the external battery wires do.  Which is (+), or does it matter?
      I've read the instructions three time, and find no mention of this.  I'm guessing this means it doesn't matter, but I don't want to release the magic smoke.
      This post was edited by Steve Featherkile at October 14, 2017 7:09 PM EDT
    • October 14, 2017 7:32 PM EDT
      • Penacook, New Hampshire
      • Posts
        201
      • Thanks
        0
      • Thanked
        35
      Hi Steve, no it does not matter. The input on the Revo II is not polarity sensitive.  This is the same input that track power uses. Out of habit I connect the red battery wire to the outside input screw. At least this way I always know where the positive terminals is should I need It later.
      Enjoy,  Don
    • October 14, 2017 7:48 PM EDT
      • Posts
        12,551
      • Thanks
        558
      • Thanked
        356
      Don, thanks for answering.
      What input screw?  What am I overlooking?
    • October 14, 2017 8:06 PM EDT
      • Berkshire, Ma.
      • Posts
        758
      • Thanks
        154
      • Thanked
        49
      Looks like Don has left the house so I will add my 2 cents what Don is talking about is using the little adapter board that comes with it. Sounds like you are doing a plug and play. Sounds like your doing just fine. your putting a on off in switch right.
      Richard
    • October 14, 2017 10:33 PM EDT
      • Posts
        12,551
      • Thanks
        558
      • Thanked
        356
      Richard
      Yes, I'm using a separate on/off DPDT switch, in the form of Don's BIK.
      Do I need to use that adapter board?  Isn't that for non plug'n'play?
    • October 15, 2017 12:14 AM EDT
      • Be Nice or STFU
      • Posts
        9,371
      • Thanks
        248
      • Thanked
        858
      Steve, what loco? It sounds like you are using one with a socket.
      Here's a revo with the heat sink off. 4 of the "bugs" do the motor control, and the other 4 are a full wave bridge, which allows power in any polarity to the "track" inputs. The track inputs are pins 1&2  and 12&11 (2 pins for each "rail" so to handle more current).
    • October 15, 2017 12:26 AM EDT
      • Posts
        12,551
      • Thanks
        558
      • Thanked
        356
      I'm working with my SD45s, both with Navin's new boards.  Trying to get onboard batteries.
    • October 15, 2017 12:57 AM EDT
      • Be Nice or STFU
      • Posts
        9,371
      • Thanks
        248
      • Thanked
        858
      So where are you connecting the battery to? are you using one of the "mu" connectors that stick out of the ends?
    • October 15, 2017 7:57 AM EDT
      • Posts
        12,551
      • Thanks
        558
      • Thanked
        356
      No, my idea is to solder the power into the board where the "mu" leads are soldered.  I can't think of a better spot.
    • October 15, 2017 8:18 AM EDT
      • Berkshire, Ma.
      • Posts
        758
      • Thanks
        154
      • Thanked
        49
      Steve Don was just using that as a example. What you are doing is just fine. I have done the same and had good luck. I mount the switch by the other switches and put a connector between the switch and were you are soldering the wires on. Just make sure you are not back feeding power to rails I know this is a new board but just to check.
      Richard
    • October 15, 2017 8:58 AM EDT
      • Posts
        12,551
      • Thanks
        558
      • Thanked
        356
      Richard, thanks for the heads up on checking the back feed.  The new SD45 board from Navin has the track/battery switch wired backwards.  Why the Chinese decided to do that is unknown.  They may have screwed up elsewhere.
      This post was edited by Steve Featherkile at October 15, 2017 9:00 AM EDT
    • October 15, 2017 9:13 AM EDT
      • Berkshire, Ma.
      • Posts
        758
      • Thanks
        154
      • Thanked
        49
      Steve check where the main plug goes to the frame I found one with wires switched that go to that switch. I just pulled wires out of the connector and put right all was good. did you use the frame wire all so from Navin?
      Richard
    • October 15, 2017 10:43 PM EDT
      • Posts
        12,551
      • Thanks
        558
      • Thanked
        356
      Richard
      Richard, I'm sure this is clear to you, but, forgive me, I don't have a clue what you are talking about ( Insert clueless emoticon here ).
    • October 15, 2017 11:27 PM EDT
      • Berkshire, Ma.
      • Posts
        758
      • Thanks
        154
      • Thanked
        49
      Ok Sorry Steve 2 sets of wires come from the main board the one you just replaced one set has 6 wires and the other has 7 wires. both sets plug into the wires in the frame. What i was talking about was the set of 7 wires. those wires should be all in line with the wires on the main board the end wire should be the end wire on the plug and so on. I had one that was crossed and things did not work right. All I had to do was straighten them out. This set of wires are the power the other set is lights. My last question was if you changed the wires in the frame. Hope this is a little clearer.
      Richard
    • October 16, 2017 12:13 AM EDT
      • Be Nice or STFU
      • Posts
        9,371
      • Thanks
        248
      • Thanked
        858
      interesting, the battery / track switch cannot be wired any different, since it is connected directly to the pcb.. all you can have is a different pcb...
      I'll be publishing my wiring nightmare with my SD45 soon.
      I'd wire the battery in, and then test to see if there is a switch position that does not put power to the wheels before I'd start cutting / unplugging...
    • October 16, 2017 1:58 PM EDT
      • Posts
        12,551
      • Thanks
        558
      • Thanked
        356
      It is a complete new design, Greg.  It only has a passing resemblance to the old board.
    • October 16, 2017 2:33 PM EDT
      • Posts
        12,551
      • Thanks
        558
      • Thanked
        356
      The wiring is fine, Richard.  Thanks for all your help.  There are those who question whether I should be trusted with the operation of a light switch, so I proceed slowly, triple checking each step.
      This post was edited by Steve Featherkile at October 16, 2017 2:35 PM EDT
    • October 16, 2017 2:59 PM EDT
      • Berkshire, Ma.
      • Posts
        758
      • Thanks
        154
      • Thanked
        49
      Steve sounds good you don't want it to cost more than it all ready has. As far as the switch goes it is all good they just changed it with the new design. I do have to ask, you did bolt the regulator to the frame or one of the bolts that hold a weight on?
      Richard
    • October 16, 2017 4:27 PM EDT
      • Posts
        12,551
      • Thanks
        558
      • Thanked
        356
      Richard
      I did, indeed.  What is that for?
    • October 16, 2017 5:49 PM EDT
      • Berkshire, Ma.
      • Posts
        758
      • Thanks
        154
      • Thanked
        49
      Steve its the voltage regulator for the lights by bolting it to the frame, the frame acts as a heat sink. With 18.5 volts i'm sure it will get a little warm. I also believe it takes the place of that board that is bent up at the end of the old main board.
      Richard
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
