Changing out 2nd set of lights.
Having done the observation car, I turned my attention to the coach this morning...
First, I took the bottom off the car...
Followed by removing the 9-volt battery box, and the wiring for the current lights...
These are the lights I'm using, purchased from the local craft store, already wird to a battery box for 3 AA batteries...
I attached the battery box where the old box came off using two-part epoxy...
The wired LEDs get run through a hole in the bottom of the car. The hole gets sealed with clear silicone sealant.
I ran the LED string back and forth along the rib for the old lights 3 times. The extra wire and LEDs get cut off. The lights get held in place with tape until the silicone I used to hold it in place dried.
Exterior of car after new battery box is painted, and the car is reassembled with the wire routed where I wanted it.
Car lit up with new lights...
Now I have the combine and baggage car to do.
