Pete Lassen said:
Cliff reading the questions at the bottom, it sdays to let it cure for 28 days then paint with a sealant to waterproof. So, it may not be good for piers, not sure if sealant will need to be re-applied. I may get a tub to see what can be done with it, or just read the label to see what it says
Good point Pete. But here’s another FAQ answer,
Do I need to seal? If not, when is it recommended?
While you don’t have to seal your project, sealers reduce the natural porosity of concrete and this will help create a resistance against staining. It’s recommended for projects that you want to minimize natural wear and patina. Ultimately, use a sealer—or don’t use a sealer—depending on what type of concrete surface finish you desire.
It sounds like, if I don’t care about staining / appearance, it’s ok.
