The trip back east to run trains on Ken’s great layout taught me a few things and motivated me to get working on the final leg of my outer loop. Up until now I have been limited to running back and forth on a few hundred feet of track with only a wye at one end. After seeing all the rock and dirt work that Devon has been doing, I decided that I can’t let that young whipper-snapper get his layout built before me. After all, age and cunning beats youth and exuberance anytime.
The section that I need to complete runs from the patio area behind the house, around the west end of the layout, and across the south edge back to the gazebo area. It’s about 180 feet of track, not counting sidings. I call the climb around the west edge Windy Point. Here the track climbs on a 3% gradient from the front of the layout to the rear. Here is a view of the Windy Point section.
I moved the rocks onto the layout yesterday. Some of the larger ones are a couple of hundred pounds each. I used that 4 x 6 timber setting on the block wall as a big lever to get those monsters up there. Here is the view from the west edge of the layout looking downgrade. The track will run just inside of the block wall with the rocks towering above it. I also moved about three yards of dirt to fill in behind the rocks. This area will have a forest of Alberta Spruce eventually and a logging spur from the inner loop.
Here is the view along the south edge of the layout taken from about the same spot as the previous photo. The track will run near the block wall all the way to the gazebo (seen on the far left through the shrubs.) That area in the foreground is my temporary planting bed. Each fall, when Lowe’s and home Depot put all their nursery plants on sale for 50% to 75% off, I buy some and stick them in the ground to over Winter. That way I always have cheap trees to plant when needed.
I’ll keep you guys posted as I make progress on this construction. Right now, I’m shooting for the mid-June time-frame for the golden spike on the outer loop.
Bob
