Are the End Railings and Handrail Stanchions of Aristo’s Little Critter the same parts as the RS-3?
I found a PDF of the Little Critter (attached). The parts look the same on the parts diagram.
Thank you in advance.
Looking at the RS-3 exploded parts list, the front and rear end railings are item 59 in the drawing, p/n 22200-59.
From your little critter parts lies, it is item 51, p/n 82100-51.
Not sure they are the same, would have to measure each out to be sure, the end platforms are not the same between the 2 locos as far as I can see.
The hand rails and the uprights on the little Critter are the same as the short end of the RS-3. The Little Critter was made from the cab and short section of the RS-3 with a single motor block.
Chuck, the RS-3 parts list has the same part number for both ends of the loco.
The front and rear hand rails are different on the lil critter.
