My latest project.
Bashed a USAT 70MAC for the body, added some doors
for some reason photo won’t add properly ???
My latest project.
That’s a great job Bill, I love seeing Diesels that aren’t mass produced in large scale.
Bill, that’s awesome! I can’t believe how much longer the SD-60 seems with a “Spartan” cab. Is the cab bashed from another USA engine?
Great work Bill
VERY NICE!
Hello All
Thanks for your kind words
Compliments are hard to come by sometimes.
I’m NOT the best with a camera so the pics will be few on my projects.
The cab is from an Aristo SD-45 but I think one from a SD-40-2 would also work.
Just needs a little “plastic surgery” on the frame to make it fit.
Check conrail cyclopedia website for prototype photos if you are going to try this
It was surprisingly easy. Next project is a GE 8-40C from a GE 9-40c
Bill
looks great! I would like to see more images
thanks
A big tip-o-the-hat from this dyed-in-the-wool steam guy! That looks great. I had family who lived next to Conrail’s tracks in Southern Maryland, so a well-executed Conrail model brings back lots of memories.
Very nice!
Bill Z said:
Hello All
Bill
I have been advised by a friend of big power that the SD40-2 cab won’t fit, it’s “too wide for the frame”.
He asked me to post this for all y’all as he mostly lurks here checking up on me(http://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-innocent.gif).
John
John
Your friend is right. the SD-40-2 cab is just under 1/4 inch wider than the SD-45 cab.so it would hang over each side by 1/8 inch. definitely noticeable and not easily “fixed”. I hadn’t really looked closely before.
Thanks for the heads up.
Bill
The fix for the wider cab (SD 40-2 ) would be to glue a 1/8 x 3/8 plastruct strip to the edge of the frame on both sides. It means re-drilling all of the handrail holes and painting the top edge black , but that would work if you don’t have a spare SD-45 cab.
Bill
Looks great Bill . What did you use for the truck side frames ?
I just used the 70 mac trucks I’m not much of a rivet counter. if you want prototype
you can use SD 40-2 sideframes.
the older SD-50’s used both old flexcoil trucks (like on SD 45 )and newer HTC trucks.
SD60 was all HTC. like SD 40-2.
Biil
After posting the above reply, It started to bug me so I swapped
the sideframes for ones off of a SD 40-2
How did you do the patch?
looks great
John S
What patch are you referring to?
The brake wheel on the long hood is covered with a 1/16 styrene door as are several of the louver openings that are not on a SD 60.
If tou mean fitting the cab to the frame , It s drop-in just made new screw holes to keep it in place.
Side frames were a direct swap out with mounts. Both are USA Trains.
I hope i answered your question.
Bill
