Piko Mogul Wiring Diagram
I just scored a nice, slightly (hardly ever) used Piko Mogul. I want to convert it to RC/Battery with my Railboss and Myloco sound. Does anyone have a wiring diagram for the tender connections? I read somewhere that you can use the Piko PC board in the tender and just make the connections there.
Thanks
Bob
Hi Bob, I have converted several Piko Moguls with and without sound. The Piko sound version uses a Tsunami decoder board and it must be removed. The board is not compatible to any PWM motor drivers. You can easily use the wiring to make all your connections.
I did not keep the Piko second circuit board. If you look on page 19 of the manual there is a wiring diagram or I can email the page and a photo of the install. You basically take their wires as labeled and connect them to your throttle. I added dropping resistors for the LED headlights.
Don
Hi Don,
I have the version without sound. Since I picked thi up second hand, I do not have the manual. I would love it if you can email it to me.
Thank You
Bob
