In this episode of This Old Mill, Smokey extols the virtues of steam power, Chuck falls off the wagon, the coal wagon. Phil Thee demonstrates a new cleaner that he just discovered, Formula 409, and Old Lady Strawbridge…
Sorry, wrong script.
Today I started with covering the rebuilt first floor with cut stone. I started in the most visible corner of the mill, because I want that corner as good as I can get it.
Then I worked out where to tape my straight edge to the mill, so the stone would be laid (stacked) straight.
Then I started laying the stone. I am not going to bother wasting much stone under where the truck door will be. Later I may put some of the unusable stone there to support the door.
Once the stone was laid down to my straightedge, I moved it down a few more courses and continued laying the stone. I am adhering it to the coroplast with almond coloured silicone caulk. I chose the almond colour, so if any of it is visible between the stones, it wont stand out like white caulk would.
You may also notice, on the left side, that I am not laying stone over to where the remains of the truck door are. That’s because a man door goes there. I am not laying those stone until I build the man door. Then I can place the stone so that everything fits properly.
Once that end was done, what, no picture? Crud! I started on the side. Since I had laid the stone in the corner already, when I did the front, I knew where my courses should be, and I drew a few guidelines to help me keep the courses straight.
There will be windows in the first floor, and I was able to find, in my stash, some of the same type of windows that were originally in the first floor.
Yup, you guessed it. Those windows were cut from a florescent light diffuser.
This where I stopped for the evening.
